This page provides information on the V-Ray BRDFToonMtl node.
Section | |||||||||||||||||
Toon
Anisotropy
Shadows/Light Control
Toon Transparency
Edges Override
Diffuse
Bump
Reflection
Refraction
Options
Anchor | ||||
Example: Diffuse Ramp
This examples shows the effect of the Diffuse Ramp. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
Section | ||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Edges Override
This examples shows the effect of the Edges Override parameter. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
Anchor | ||||
Example: Diffuse Color with Diffuse Ramp
This example shows the effect of the Diffuse Color when used with a Diffuse Ramp. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
Section | |||||||||||||||||||||||||||||||||||||||||||||||||
