This page describes the Diffuse Render Element and how it is used to have more control of a final composited image.
Section | |||||||||||||||||
Attributes
Common Uses
The Diffuse Render Element is useful for changing the appearance of many passes when it is combined with Raw render passes (like Raw GI, Raw Light, etc.).
Diffuse x Raw Shadow = Shadow
The Diffuse is a very useful render element due to the number of raw passes with which it can be combined, giving the ability to manipulate many areas of the render at the composite level. The Diffuse pass can also be color-corrected on its own, as shown in the example. In this case, a Multi Matte Render Element is used to isolate the cloth on the sofa. The Diffuse Render Element is used to change the cloth's color from yellow to blue. This method avoids tinting the lighting or shadowing of the scene.
Section | ||||||||||||||||||||||||||||||||||||||||
