V-Ray 6, update 2.
2
Anchor
build_hotfix21hotfix6.2.2
Official release
Date - Mar 27May 30, 2024
Build 6.20.0102
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray for Maya
urlhttps://download.chaosgroup.com/?platform=48&product=47
New Features
V-Ray
  • Maya 2025 support
  • Allow selection of USD provider in V-Ray standalone
  • Added support for 0.23.11 USD for V-Ray standalone
MaterialX
  • Support for MaterialX Stack
  • Added support for color space correction of image nodes
  • Added  AdobeRGB and Display P3 color space support for image node
MaterialX, V-Ray GPU
  • Extended initial support for MaterialX nodes on GPU
Chaos Scatter
  • Added support for Altitude
  • Added support for Camera Clipping
  • Added support for Planar mapping
Chaos Vantage
  • Render Animation with Chaos Vantage
  • Added Vantage Live-Link Settings
  • Added Cancel Vantage Live-Link option
VRayEnvironmentFog
  • Add Phase Function to Environment Fog
Modified Features
MaterialX
  • Add support for procedural textures
  • Add support for colorcorrect and randomcolor nodes
  • Allow negative colors for all textures in MaterialX
  • Add closest filtertype support for image node
  • Add support for Pivot and Scale in place2d node
  • Add fileprefix attribute support
VRayLightMeter
  • Add MEL command for average Total value
Bug Fixes
V-Ray
  • Fixed low Dynamic memory limit in old scenes
  • Fixed IPR crash when adding lights to scenes with specific Cosmos assets and VRayLightMix
V-Ray GPU
  • Fixed matte properties not working on some V-Ray materials
  • Fixed one-sided geometry not rendering
  • Fixed disabling Visibility Options not working
Chaos Vantage
  • Fixed a freeze when Vantage Live Link cannot find a suitable GPU device
MaterialX
  • Fixed SSS scale
  • Use degrees instead of radians for the place2d rotation values
  • Fixed rendering of Academy software materials
  • Wrong gamma applied to MaterialX image node
USD
  • Retain material connection when duplicating geometry from USD stage to Maya Data
VRayHairNext
  • Fixed artefacts and slowdowns in some scenes with VRayHairNext
VRayScene
  • Fixed IPR crash with proxy inside a .vrscene loaded in Geometry mode in Maya
VRayTriplanar
  • Fixed Rotation Texture in VRayTriplanar not exporting connected nodes
V-Ray 6, update 2.1
Anchor
build_hotfix21
build_hotfix21
Official release
Date - Mar 27, 2024
Build 6.20.01
New features
USD
  • Added support for VRaySubdivisions as geometry attributes;
  • Added support for custom camera plugin
  • Use System Memory mode for texture loading
  • Direct Diffuse and Direct Specular shadow select render elements support
  • Support for VRayEnmesh
  • Support for Image planes
  • Add support for Raw render elements in V-Ray GPU
Modified Features
USD
  • Export to USD has been updated to be Hydra-compatible
  • Exporting UV sets to USD will now preserve set names
  • Support for MayaUSD 0.26.0 for Maya 2024
  • Droped support for MayaUSD versions lower than 0.16
  • Optimise USD export file size when one texture node is mapped to multiple input slots
  • Improved geometry compilation for instanced USD
  • VRayMtl SSS is written in Refraction render element
Bug Fixes
USD
  • Export Dome lights textures with arbitrary node graphs
  • SettingsVFB not exported to USD
  • IPR support for animation
Date – May 18, 2023
Build 6.10.00
New Features
V-Ray
  • Added support for Chaos Scatter
  • Added support for Maya 2024
  • Added support for Maya 2024 macOS universal builds for Apple Silicon and x86
  • Implemented a Bump To Glossiness model
  • Added light attenuation controls for custom decay
  • Added support for emissive materials in VRayLightSelect and VRayLightMix
  • Implemented Intel Open Path Guiding rendering with Light Cache (experimental)
  • Added NVIDIA AI upscaling denoiser
Modified Features
V-Ray
  • Faster rendering and geometry compilation of hair
  • Faster mesh geometry compilation
  • Improved progressive caustics convergence
  • Added support for multiple VRayEnvironmentFog nodes as Environment Volumes
  • Аdded Affect Alpha option for VRayAerialPerspective and VRayEnvironmentFog
  • Added an option to delete the resumable file when resumed rendering completes successfully
  • Scripts for starting vrayserver from portable installation now auto-discover paths
  • Dropped support for Maya 2019
  • Installer no longer modifies Maya MEL scripts
Bug Fixes
V-Ray
  • Execute Pre and Post Render MEL scripts in Viewport IPR. This allows rendering 3rd party plugins like Yeti in Viewport IPR.
  • Fixed artifacts with Adaptive Lights on Linux
  • Fixed EXR with just a red channel not rendering correctly
  • Fixed error "Extra attributes file not found"
  • Fixed renderable curves not working with Render Layers
  • Fixed a crash with VRayBerconNoise driving density of volume and displacement with UVW Explicit 2D
  • Fixed region render in IPR restarts the sampling
  • Fixed wrong Material Viewer render with ACEScg
  • Fixed Light Cache not working correctly with render regions in IPR
  • Fixed wrong source visibility when creating VRayEnmesh while IPR running
  • Fixed Enmesh Force Invisible Source not working in IPR with a moving source
  • Fixed animated V-Ray Perfect Sphere not animated in the viewport
  • Ability to combine randomization options in VRayMultiSubTex
  • Added "by user ID" random option in VRayMultiSubTex
V-Ray IPR
  • Light cache support option for IPR
V-Ray GPU
  • New GPU device selection tool
USD
  • Support for VDB shaders in USD
  • Add support for MayaUSD versions up to 0.19
Chaos Cloud
  • Non-blocking Cloud export in the background (Windows only)
VRayEnvironmentFog
  • Faster light shading in fog
  • Faster textured fog with probabilistic shading option
VRayVolumeGrid
  • Added support for light depth sampling in the volume grid
  • Phase Function control in Ray-Traced Scattering mode for the Smoke Color allowing to render realistic clouds with V-Ray CPU
  • Velocity and Normals render elements in Volumetric mode with V-Ray 6 CPU
  • Cryptomatte and Multimatte render elements in Volumetric mode with V-Ray 6 CPU
  •  New "Volume Motion Blur" option allowing to choose between Ray-traced and Grid-based methods - the Grid-based method creates more visible streaks for fast moving fluids
Modified Features
Installer
  • -unpackInstall option to produce portable installation instead of separate zipped install
  • Added all V-Ray for Maya environment variables to the module file for easier portable install deployment
  • Changed default installation paths to be outside the Maya folder, matching portable install folder structure
  • Use online changelog
  • Embeded the Chaos Unified Login
  • Stop downloading the material library from the installation
  • Use dedicated icon for VRayProxy in the Outliner
Chaos Cosmos
  • Added support for Cosmos procedural materials and Cosmos-based material library
VRayMtl, Viewport 2.0
  • Viewport quality presets for VRayMtl
  • Add support for the V-Ray 6 VRayMtl features in the Viewport 2.0 shader
  • Support for Normal and bump maps with V-Ray materials in Viewport 2.0
V-Ray GPU
  • Added a new Samples Limit quality control that replaces the min and max subdivs for GPU
  • Auto-upgrade old scenes to the new Samples Limit control
  • Synchronize CPU bucket settings with the new samples limit GPU settings
  • New Device Selection options
  • Moved the RTX engine selection to the new Device Selection options
  • Add denoising options and per-device low thread priority in the GPU device select
  • Exposed the Global Material Overrides for V-Ray GPU
  • Improved the Trace Depth workflow
  • Support for "Affected by" in VRayDirt
  • Implement auto bump mapping for smoothed and displaced meshes
  • Autovoxelize dynamic geometry in V-Ray GPU
V-Ray
  • Optimize memory consumption by not subdividing objects that are far away from the camera
  • Redesigned the V-Ray Shelf and Material icons
  • Added a Shadow Catcher functionality to the V-Ray shelf
  • Added a search filter in the list of available render elements
  • Added an option to always write the frame number to the output file even for still images
  • Allow vfbControl MEL command in batch mode
  • Ability to prevent proxy import when drag-and-dropping in Maya through VRAY_DISABLE_DRAG_DROP_FILEEXT envvar
  • Use float controls for the explicit displacement bounds values
  • Added a C++ API for exporting simple parameters for third party translators
  • The VRAY_FOR_MAYA_SHADERS environment variable can now be used by third-party devs to point to additional extra attribute txt files
  • Add fit aspect ratio to material/bitmap functionality for VRayDecal
USD
  • Added support for dynamic USD plugins
  • Improved USD material importer UI
  • Export VRayMtl as V-Ray material and USD Preview Surface
  • Improve error handling and add help to the vrayExportUsdMaterials command
  • Assume -chaser "vray" flag when using mayaUSDImport command
VRayMtl
  • Added a Soap Bubble material preset
  • Hide the double-sided option in VRayMtl
Material Importer
  • Add VRayMultiSubTex support in importer
  • Add native support for MtlGLSL in importer
VFB
  • Added a "Show in folder" option to the VFB History context menu
  • Added functionality to select lights in LightMix
  • Better visibility of the A|B line in the VFB
  • Add menu items for enabling/disabling history and layers
  • Mark the scene dirty when making changes to layer compositing in VFB2
LightMix
  • Added options to include the Rest channel when saving to file and to Denoise the Light Mix
Denoiser
  • Expose temporal mode option for NVIDIA denoiser
V-Ray ExtraTex
  • Added a custom background color option in VRayExtraTex render element
V-Ray IPR
  • IPR should stop sampling after reaching the noise threshold
VRayEnvironmentFog
  • Аdded an Affect Alpha option for VRayEnvironmentFog
VRayMtl, VRayBumpMtl
  • Hide Local space bump map mode for BRDFBump and BRDFVRayMtl
VRayLightDome
  • Restored the Ray Distance options for the Dome light
VRayTriplanar
  • Added VRayTriplanar option to use displaced surfaces
VRayOSL
  • Support OSL camera shaders
ChaosCloud
  • Allow direct cloud submit with no project selected
VRayDecal
  • Animatable VRayDecal parameters
VRayProxy
  • Correctly apply proxy material overrides in the viewport
  • Limit number of faces per voxel to a sensible number
XGen
  • Enable parallel XGen export
Viewport IPR
  • Rename Viewport HUD label from VRayRT to VRay IPR
VRayVolumeGrid
  • Sped up rendering of grid volumes with up to 25% when Fully Visible Fire or Volume Light Cache is used
  • VRayVolumeGrid: Sped up rendering of grid volumes with up to 10% when the RGB channel was used
Bug Fixes
V-Ray
  • Fixed a crash on macOS Monterey caused by exceeding the OS max file handle limit
  • Fixed old scenes randomly using OCIO Display correction when rendered in batch
  • Wrong viewport preview for TX textures from Cosmos on macOS
  • Fixed memory tracking results discrepancy for "Texman" and "Tiled bitmap"
  • Wrong font on installer on MacOS
  • VRayTexOCIO Maya node crashes when used with Maya software renderer
  • VFB2 OCIO display corrections not synced with Maya in batch
  • Reflections computed in fully diffuse VRayMtl materials
  • Time reported by the progress for "Compiling geometry" is incorrect in Standalone
  • Memory leak in TexLut
  • Memory leak when saving multichannel/multipart OpenEXR files
  • TexLut fails to read file on Linux when the path is specified with backslashes
  • BitmapBuffer: <frame0*> tag support
  • VFB2 OCIO display correction not found with Maya batch on Linux
  • Wrong vrscene lights export when combined with "Separate files" option
  • Print a message for unsupported Chaos Cosmos Browser for Maya 2019 on both Linux and macOS
  • Ray derivatives are not computed for perfect refractions
  • Incorrect reflection on objects with motion blur and vray subdivisions
  • Recalculating bloom/glare lens effects produces artefacts on Linux
  • Error when selecting "Lens File" Distortion type of V-Ray Physical camera in IPR
  • Standalone installation cropped UI on HighDPI MacOS
  • Standalone installation cannot start a distributed rendering server on macOS
  • Log typo in Estimated time remaining line
USD
  • Fixed endless warnings for USD export material with UV linking
  • Importing V-Ray materials via mayaUSDImport does not work with MayaUSD 0.16
  • Invalid handling of instanced non geometry primitives
  • Show the warning for unsupported USD versions during render
  • Physical camera from USD scenes are imported with Depth of Field enabled
  • Mismatch with displacement in Houdini
  • Correctly export VRayMtl bump type as integer USD attribute
  • Importing USD scenes with usdPreviewSurface material is rendering wrong
  • Crash when rendering VRayMtlGLSL in USD scene with GPU
  • USD scenes with textures are imported black in Viewport
  • Crash when importing USD scenes with the -shadingMode flag and USD 0.15
  • USD scenes with particles are imported wrong in Maya Viewport
  • Locked camera parameters when imported from USD
  • Crash when importing specific USD scene with bitmap
  • Crash when importing USD scene with VRayPhysicalCamera through MEL command
  • Transform mismatch with Skel USD file
  • Unsupported shader parameters in USD
  • Fixed USD with VDB in IPR crashing on transform
V-Ray, VRayTriplanar
  • Wrong Normals when object has Triplanar mapped displacement and is a Texture Reference Object
V-Ray GPU
  • Clipped light geometry when 'Clip lights geometry' option is disabled and non-light geometry is in front of lights
  • Wrong VRayClipper material on clipped VRayLight objects when set to Use object material
  • VRayPhysicalCamera: Rendering on GPU with Depth of Field prints errors in the Log Window
XGen
  • Fixed XGen button label on high-DPI displays
Material Importer
  • Nodes connected to Thin Film attributes don't get imported in Maya
USD, Material Importer
  • Specific Skel USD scene is not rendered
VFB
  • The persistent VFB setting to resize on resolution change does not persist
  • The VFB2 test resolution button isn't reflecting the current resolution if it's enabled when re-opening a scene
  • The VFB history option to copy the scene path also copies the project path
V-Ray GPU
  • Fixed excessive memory usage and low performance with GPU Light Cache
  • Crash with Physical camera's position constraint
  • Crash when rendering specific alembic particles file
  • Some threads never finish with low_gpu_thread_priority=1
  • VRayMtl with translucency is not rendered properly after resuming a render using RTX mode of V-Ray GPU and Light cache
  • Projections using Spherical camera are not rendered correctly with V-Ray GPU
  • Instanced textured VRayLights don't share loaded textures
  • Difference in HairNextMtl on surface geometry between V-Ray and V-Ray GPU
  • Crash with GPU Light cache subdivisions set to 2000 and sample size >0.1
  • Scene with Light Cache crashes if run in parallel on Linux
  • Render time difference between V-Ray versions
  • Wrong render of VRayMultiSubTex on geometry with motion blur
  • Incorrect render with VRayEdgesTex on subdivided geometry
  • Out of core related crashes in V-Ray GPU
  • Crash with texture baking and geometry with displacement
  • Wrong fog color alpha results when refraction set to affect all channels
  • The alpha of a transparent VRayMaterial is not working correctly
  • Different alpha compared to the CPU and older V-Ray GPU versions
  • VrayLayeredTex not working with more than 6 inputs on GPU;
VRayProxy
  • Crash when importing specific alembic with particles
  • Wrong UV linking with multiple UV sets in VRayProxy
  • Textures are not shown in the viewport on some Cosmos assets
  • Proxy2 frame transformations not reflected in Viewport 2.0 in Maya 2023
Installer
  • AppSDK shipped in V-Ray for Maya installation doesn't work on Linux and macOS
Memory Tracking
  • Illegible symbols in memory tracking for Dynamic geometry on Linux
VRayStochasticFlakesMtl
  • Differences between VRayMtl and stochastic flakes with reflection glossiness=1
  • Outline on objects with VRay Stochastic Flakes Mtl
VRayHairNextMtl
  • Missing Color and Intensity in UI for lights created from PluginNode
VRayMtl, V-Ray GPU
  • Artifacts on specific scene with VRayMtl SSS translucency
  • Wrong render with SSS2
VRayProxy, Cryptomatte
  • Cryptomatte's VRay user attribute ID type does not work with alembics in VRayProxy
VRayProxy, V-Ray GPU
  • The 'Per instance materials' options for alembics does not work properly in GPU
VRayToonMtl
  • Diffuse artifacts with anisotropic reflections and sheen or diffuse roughness
Viewport 2.0, V-Ray GPU
  • Rendering artifacts with anisotropy reflections
Viewport 2.0, VRayPluginNodeMtl
  • Some Maya materials are imported black in Viewport
vdenoise
  • Standalone Vdenoise tool doesn't work with multi-part .exr files
