CSS Stylesheet
.rwui_text_box {
margin:0px;
Responsivegridmacro
VAlignmentstart
Columns3width1290px
Columns1width1540px
Columns2width1290px
This page provides information on the Live-Link feature from Maya to Chaos Vantage.
The Live-Link feature makes it possible to instantly see changes made in Maya without the need to export and import .vrscenes in Chaos Vantage.
Additionally, you can export and send an animation for rendering directly from Maya.
Live-Link Setup
For Live-Link to function properly, please follow the steps below:
UI Text Box
typeinfo
Vantage Live-Link only works with Windows® operating system.
Installation
UI Text Box
typenote
Live-Link works only with V-Ray 5, update 2.2 or newer.
width50%
1. Download and install the latest official V-Ray for Maya build from the download button. Make sure you have appropriate licenses. If you experience problems, please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray for Maya
urlhttps://download.chaosgroup.com/?platform=48&product=47
width50%
2. Download the latest Chaos Vantage build from the download button. Make sure you have appropriate licenses. If you experience problems, please reach us using the Support Form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage
urlhttps://download.chaosgroup.com/?platform=47&product=63
After installation, Live-Link can be initiated:.
Live-Link to Vantage
width50%
Use the Live-Link to Vantage button in Maya from the V-Ray shelf or the option in the V-Ray menu. Click the button and a Live-Link session is initialized between Maya and Chaos Vantage. It automatically:
Fancy Bullets
typecircle
    • Starts Chaos Vantage if it is not already running.
    • Sends the scene to Chaos Vantage on 20701 port.
When Vantage is initiated:
    • This temporarily changes the render settings of the scene.
    • Distributed rendering is enabled.
    • All IP addresses are replaced with a single local Vantage host.
    • The Vantage window opens, if it is not opened already.
    • The Vantage server starts and you can now make changes to the Maya scene and they will be visible in Vantage.
UI Text Box
typetip
Live-Link cannot start while a render is running and vice versa - a render cannot start while Live-Link is running. In these cases, an error message appears in the Script Editor.
width5%
width45%
Align
alignright
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/5iifWAsLkuo" title="Chaos Vantage  — Live Link from Maya" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
width50%
Once a Live-Link session is started, the scene is transferred to Chaos Vantage, a blue outline appears in the Vantage viewport and a message is displayed at the top of the Maya viewport saying Vantage live-link running. Use the V-Ray shelf to stop.
UI Text Box
typeinfo
The Pause when app loses focus option in the Preferences menu is ignored when in a Live-Link session.
To stop a Live-Link session, click again the Live-Link  to Vantage button in the V-Ray shelf. Once the session is stopped, all render settings go back to their original state.
width5%
width45%
Vantage_Viewport
Render Animation
width50%
You can export and send an animation to Chaos Vantage for rendering directly from Maya.
Select the Render Animation with Chaos Vantage option from V-Ray shelf or V-Ray menu. An export of the current animation starts and sends it to Chaos Vantage.
In Chaos Vantage, the Render setup window opens with Sequence selected in the settings. You can adjust the render settings and select a directory, where the animation is written.
Note that the animation considers the Time Slider's Animation Start/End options and the scene's FPS.
Once the animation starts rendering, Maya interface freezes. To abort the animation, use the LiveLink Animation window that pops up.
After the animation is exported and the animation frames are written, the live-link between Maya and Vantage stops. If you want to keep it active, use the Keep live link active on render end option in Maya.
width5%
width45%
Image Added
Supported Features
Not all V-Ray for Maya and Maya plugins are supported. For a full list, please visit the Supported Features page.
