This article shows how to illuminate a scene with Corona Sky map, its setting and examples of usage.
Section | |||||||||||||||||||||||
Section | |||||||||||||||||||||||||||||||||||||
Corona Sky Texmap
Usage Workflow
Corona Sky and Corona Sun Intensity and Shadow Sharpness
Sharpness of Shadows
By default, Corona Sun casts sharp shadows because it is not "blurred" by any layer of clouds or haze that would exist in the real world. To get softer shadows, you can simulate the sunlight being scattered over a larger surface of the sky dome by increasing the sun size:
Section | ||||||||||||||||||||||||||||||||||||||||
You can also control your scene exposure globally to make the overall image brighter or darker:
Sky Models and Parameters
The PRG Clear Sky Model was introduced in Corona Renderer 6. It provides greater accuracy, and most importantly, the sky continues to be accurately illuminated when the sun is below the horizon, down to as low as -2.85 degrees (or, approximately 5.4 sun diameters below the horizon), which enables dawn and twilight effects. You can see the difference with the sun below the horizon in the comparison below:
The PRG Clear Sky Model also removes a greenish tint that was cast into the scene when using the legacy Hosek & Wilkie Sky Model:
PRG Clear Sky Model - Horizon Blur
Section | |||||||||||||||||||||||||||||||||||||||||
PRG Clear Sky Model - Ground Color
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Rawa-fake
Rawa-fake is a "fake" (non-physical) sky model, which allows for easier customization (the Zenith color, Horizon color, Sundisk glow, and Sun colorbleed values can be changed under "Rawafake model parameters" once this model is selected).
Hosek & Wilkie
Hosek & Wilkie was the previous recommended and most realistic sky model (in Corona Renderer 5 and older). It produces realistic results, however it has some disadvantages compared to the PRG Clear Sky Model - for example, it does not allow rendering of the sundisk below the horizon and casts a greenish hue into the scene - see the description at the top of this "Sky models and parameters" section)
Using Multiple Corona Skies and Corona Suns in a Single Scene
Multiple Suns and Skies
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Using Corona Sky and Corona Sun with LightMix
Adding Clouds
Tutorial: Procedural Clouds with Chaos Corona for 3ds Max
HTML |
<center><iframe width="560" height="315" src="https://www.youtube.com/embed/vgUlIsHQ8Ao" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe></center> |
/iframe></center> |
Clouds Examples
Panel |
Additional Examples, Tips & Tricks
UI Expand | ||||||||||||
UI Expand | ||||||||||||||||
UI Expand | ||
If you set Corona Sun color to direct input - clouds will be colored based on the sun's color: |
UI Expand | ||||||||||||||||||||||||||||||||||
