Progress Bar Container
step2
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
url Installation
titleStep 2: Activate your license
urlChaos License Quick Start Guide
titleStep 3: Load V-Ray in Maya
urlV-Ray Configuration
Multiexcerpt
MultiExcerptNameLicense Start
Activate the License
The Chaos License
Server is the bridge between the Chaos Product and the Chaos Account associated with a given license. You cannot use any Chaos product without a license.
Depending on your license subscription, the Chaos License Server can run locally on your machine or remotely on a machine you have access to. If you are hosting a Premium Chaos License Server for multiple machines, please see the Administrator Workflow.
Please follow the instructions for your subscription plan
Panel
borderColordarkgrey
titleColorwhite
titleBGColordarkgrey
borderStylesolid
titleSolo User
The Solo License requires the server to be installed directly on your machine. The Solo License can only be used by a single user with a user login.
Fancy Bullets
typecircle
  • Download your Chaos product(s). Open the installation wizard and follow through with a basic installation setup. For more information on the specifics of the installation, go to the Installation page of your chosen product.
  • After the installation is complete, you will be redirected to the Chaos License Server's Interface. If you are not signed into a Chaos account, go to the Online licensing dropdown menu and select Sign in.
Image Added
Tabs Container
directionhorizontal
auitabspage
Tabs Page
titleLocal
The Local License Server is installed directly on your machine, allowing you to manage it and turn it on and off at your convenience. With a local license, your machine is the host of the license.
When your V-Ray installation is complete, you are automatically redirected to the License Server webpage. The re-direct happens only with the first installation.
ClickSign infrom theOnline licensingmenu.
Fancy Bullets
typecircle
  • You are then prompted to enter your username/email and password.
  • Once the activation is successful, you will be able to see the list of your available licenses on the Chaos License Server home page.
UI Text Box
typenote
Image Removed
If you accidentally close the window, you can
either open the Manage Chaos License Server shortcut or
type 127.0.0.1:30304
in
/ localhost:30304 in a web browser. Keep in mind that you cannot use any Chaos products without an active license!
Panel
borderColordarkgrey
titleColorwhite
borderStylesolid
titleRemotePremium User
The Premium License can be shared between multiple users and devices. One machine serves as an administrator and allows others to join. If you are setting up a machine to administer a Chaos License, please see the Administrator Workflow page.
Fancy Bullets
typecircle
  • The administrator needs to give you their machine's IP address. This serves as your connection point to the Chaos License.
  • When installing your Chaos product, at the Licensing step, select Remote. In the Primary License Server field, type the server IP address that your license administrator gave you. At the end, add the :30304 port.
width25%
width50%
Image Added
Example screenshot
width25%
Fancy Bullets
typecircle
  • Continue to finish the installation. As long as your license administrator's license is active, you can use the remotely shared license.
Connecting to a Remote Chaos License Server does not require activation.
If you wish to access the server's settings, you can type the_server_IP:30304 to access the License Server webpage. Here you can browse all available licenses and some of the server settings. Keep in mind that you cannot use any Chaos products without an active license!
Borrow Licenses for Offline Use
You can also 'borrow' a license to use offline on a machine
with unstable or with no internet access.
For more information, see the Borrowing Licenses for Offline Use page
Advanced Settings
typecircle
Troubleshooting
If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions.
Panel
borderColorred
borderStylesolid
Visit the License Server section of the documentation for further details on the Chaos License Server, such as how to check your license expiration and status, how to access various settings, and more advanced options
For macOS, use sudo launchctl load /Library/LaunchAgents/com.chaos_group.vrol.plist to start the service, and sudo launchctl unload /Library/LaunchAgents/com.chaos_group.vrol.plist to stop the service. These commands are entered in Terminal and will prompt you to enter your macOS user password.
See the License Setup page for information on changing your license settings, running a silent installation, and other advanced uses.
Download the Chaos License Server
If you need to download the license installation separately, you can do so from the Downloads section of the Chaos website. Log in to access all available assets.
See the Installing the License Server page for the installation process.
Troubleshooting
Next Step
Go to step 3 to see how to load V-Ray in Maya.
