For the purpose of this guide, the example MaterialX shader consists of the following nodes to form a procedural texture:
Fancy Bullets
type
circle
two standard surface nodes - one with magenta Base color and one with green Base color.
a mix node, which connects the two standard surface nodes as foreground and background, as well as a noise node which defines the mix. The Node Type is set to float/terminal.
a noise node, which controls the noise of the texture pattern and is connected to the mix input of the mix node.
a rotate node that introduces rotation of the pattern according to one or more axis. The rotate node's output is connected to the texcoord input of the noise node.
a multiply node necessary to scale the pattern by controlling the frequency. The multiply's output is connected to the in input slot of the rotate node.
an add node which introduces UV offset to the texture. The add's output is connected to the in input slot of the multiply node.
a texcoord node which ensures the UV placement of the texture. Note that the texcoord is an obligatory node for all textures! It is connected to the in slot of the add node.
an Output node, which is created by default within the shader network.
Such setups can be used for the creation of procedural textures such as the metal handle example here.
