This page provides information on what hardware and operating systems are required for Chaos Vantage to work properly.
HideElements
cssselector#tocVertical, #tocHorizontal
Requirements
Please make sure that your system meets the requirements listed below before installing Chaos Vantage.
RAM
System RAM should equal or exceed GPU memory (minimum 8GB RAM). It is recommended to have RAM twice the size of GPU memory
Operating system
Microsoft® Windows® 10 with Update 2004 (version 10.0.19041) or newer
LicensingVantage license with License Server 4.5.1 or newer
GPU Acceleration
DXR compatible NVIDIA® or AMD or Intel discrete GPU
UI Text Box
typeinfo
Chaos Vantage can use up to 2 GPU devices.
For NVIDIA GPUs: RTX series or newer, required driver 515 or newer1 in WDDM mode, recommended driver 537.13 or newer
For AMD GPUs: RX 6000 series or newer
For Intel GPUs: Intel Arc Alchemist or newer
Anchor
GPUMode
GPUMode
1 – GPU must be set to WDDM mode and not in TCC, otherwise Chaos Vantage will not detect it.
