width60%
The VRay Mtl material layer is created with the Add Layerlayeroption and cannot be found in the Creation menu of V-Ray Asset Editor. The parameters are the same as the the Generic material, however this layer can not be overridden.
width5%
width35%
Each Generic rollout has its own dedicated page listed below:
Thumbnailspagesettings
ThumbnailOverlayRectangleColour0,0,0
ThumbnailOverlayRectangleOpacity0.5
ThumbnailBGImageHeight250px
ThumbnailSubTextSize13px
ThumbnailTextColourWhite
ThumbnailTitleTextSize22px
ThumbnailOverlayRectangleBottomPadding10px
width4%
width25%
Thumbnail
ThumbnailTitleTextGeneric Diffuse
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Diffuse
width1%
width25%
Thumbnail
ThumbnailTitleTextGeneric Reflection
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Reflection
width1%
width25%
Thumbnail
ThumbnailTitleTextGeneric Refraction
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Refraction
width4%
width4%
width25%
Thumbnail
ThumbnailTitleTextGeneric Coat
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Coat
width1%
width25%
Thumbnail
ThumbnailTitleTextGeneric Sheen
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Sheen
width1%
width25%
Thumbnail
ThumbnailTitleTextGeneric Opacity
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Opacity
width4%
width4%
width25%
Thumbnail
ThumbnailTitleTextGeneric Bump and Normal Mapping
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Bump+and+Normal+Mapping
width1%
width25%
Thumbnail
ThumbnailTitleTextGeneric Multipliers
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Multipliers
width1%
width25%
Thumbnail
ThumbnailTitleTextGeneric Binding and Override Control
ThumbnailPageLinkhttps://docs.chaos.com/display/VREVIT/Generic+Override+Control
width4%
