This page provides information about the Start Chaos Vantage tool in SketchUp.
The Start Chaos Vantage tool helps you send your SketchUp scene to Chaos Vantage with a click of a button. It initiates a Live Link session between SketchUp and Chaos Vantage, instantly sending any changes you make to the scene to Vantage without reexporting the scene.
The Start Custom Live Link tool starts a Live Link server with settings specified in the Customized Live Link menu.
The Customize Live Link tool sets specific settings for performance.
Installation
The installation of the tools comes with the installation of V-Ray 5 for SketchUp, update 2 and later.
For detailed instructions on installing and setting up Live Link from SketchUp to Chaos Vantage, see the Live Link from SketchUp tutorial.
UI Path
Section | |||||||||||||||
Specify address and port
Usage
To use the tool, just click the Start Chaos Vantage button and a Live Link session will be initialized between SketchUp and Chaos Vantage. The tool automatically:
Fancy Bullets | ||
To stop a Live Link session, click again the Start Chaos Vantage button.
Live Link Supported Features
The following changes made in the V-Ray compatible DCC are propagated through Live Link:
Fancy Bullets | ||
Excerpt |
Responsivegridmacro | ||||||||
Known Limitations
Div | |||||||||||||||||||||
UI Text Box | ||
When the Live Link session is closed, the scene is still loaded inside Vantage but it is considered dirty and the aforementioned limitations are still in effect. A .vrscene file from the host application needs to be exported and loaded inside Chaos Vantage to enable full manipulation, editing and playback. |
type | tip |
-include | ||||||
