Version 1 Current »
This page provides information about the Start Chaos Vantage tool in SketchUp.
The Start Chaos Vantage tool helps you send your SketchUp scene to Chaos Vantage with a click of a button. It initiates a Live Link session between SketchUp and Chaos Vantage, instantly sending any changes you make to the scene to Vantage without reexporting the scene.
The Start Custom Live Link tool starts a Live Link server with settings specified in the Customized Live Link menu.
The Customize Live Link tool sets specific settings for performance.
Installation
The installation of the tools comes with the installation of V-Ray 5 for SketchUp, update 2 and later.
For detailed instructions on installing and setting up Live Link from SketchUp to Chaos Vantage, see the Live Link from SketchUp tutorial.
UI Path
To access the Start Chaos Vantage tool, in SketchUp go to:
||Extensions menu|| > V-Ray > Live Link > Start Chaos Vantage
||V-Ray toolbar || > Start Chaos Vantage
To access the Start Custom Live Link, in SketchUp go to:
||Extensions menu|| > V-Ray > Live Link > Start Custom Live Link
To access the Customize Live Link tool, in SketchUp go to:
||Extensions menu|| > V-Ray > Live Link > Customize Live Link
Specify address and port
The Specify address and port dialog, available by selecting Customize Live Link, allows you to specify IP address and port.
Address – Specifies the IP address that the Live Link connection connects to.
Port – Specifies the port at which the Live Link connection is started.
Always make sure you are using the same port in both SketchUp and Chaos Vantage!
Usage
To use the tool, just click the Start Chaos Vantage button and a Live Link session will be initialized between SketchUp and Chaos Vantage. The tool automatically:
  • Starts Chaos Vantage if it is not already running.
  • Sends the scene to Chaos Vantage on 20701 port.
To stop a Live Link session, click again the Start Chaos Vantage button.
Live Link Supported Features
The following changes made in the V-Ray compatible DCC are propagated through Live Link:
  • Editing, creating and deleting of:
    • Camera
    • Geometries
    • Lights
    • Materials
    • Textures
    • Environment
Known Limitations
The following actions can be done inside Chaos Vantage during Live Link:
  • create cameras;
  • create camera animation in the animation editor;
  • edit environment and fog;
  • add color correction effects;
  • Render:
    • snapshots;
    • HQ still image;
    • HQ sequence;
  • save .vantage file with the changes from above.
The following actions cannot be done inside Chaos Vantage during Live Link:
  • transform objects;
  • hide/unhide objects;
  • reassign materials;
  • edit lights;
  • import external(including cosmos assets) files;
  • animation playback.
The following requires a restart of the Live Link session in order to be updated properly.
  • Updating of:
    • animated V-Ray Proxy files (.vrmesh)
When the Live Link session is closed, the scene is still loaded inside Vantage but it is considered dirty and the aforementioned limitations are still in effect. A .vrscene file from the host application needs to be exported and loaded inside Chaos Vantage to enable full manipulation, editing and playback.
If a .vantage file is saved in an active Live Link session, it can be loaded in a next session or applied to a loaded .vrscene.
