Responsivegridmacro | ||||||||
CSS Stylesheet |
.wiki-content .confluence-embedded-file-wrapper.confluence-embedded-manual-size { vertical-align: text-bottom; } @media only screen and (min-width:1550px) { iframe { max-width: 600px; text-align:right; } } |
This page provides a quick starting point for operating with objects in Chaos Vantage.
Div | ||||||||||||||
Div | ||||||||||||||||
Operations
Column | |||||
Here are some of the operations you can perform with objects in Chaos Vantage: Load objectsYou can drag-n-drop any supported file (.vrscene, .vrmesh, .ply, .abc, .obj, .fbx, .3ds, .stl, .ter, .dae, .gltf) directly into Chaos Vantage and choose Open to load it.
Merge / Place objectsYou can drag-n-drop a .vrmesh or .vrscene file, choose to Place (adds the asset at the position and orientation of the indicator) or Merge (adds the asset at world position 0,0,0) the new asset in the currently opened scene. This example places a .vrscene file and adds a .vrmesh file. Select objectsAny object in a scene can be selected with the help of the Select ( ) tool (hotkey: Q).Move, Rotate, and Scale objectsYou can rotate, scale, and move each object around. Select the object and press W for moving, E for rotation, and R for scale. Press the Q key to go back to selection. Use the Esc key to deselect all objects in the scene. Alternatively, use the top toolbar buttons for Move ( ), Rotate ( ), and Scale ( ).Hide / Unhide objectsYou can also set object's visibility from the Objects tab or use the default shortcut keys, after selection, V to hide and Shift+V to unhide . |
