TheBlendmaterial settings are organized inBasicandAdvancedmodes. You can switch the mode from the toggle button under thePreview Swatch or globally from the Configuration rollout of the Settingstab.
From theAdd Attributebutton, you can select additional attributes that can add up to the appearance of the material.For more information, see theAdd Attributesection.
UI Text Box
type
tip
Holding down Ctrl(or Cmd on macOS) while while having the Add Attribute or Add Layer menu open, allows selecting multiple entries without closing the dropdown.
The context menu of the Color slot provides options to Copy and Paste, as well as to Reset the color.
A Reset option is provided in the context menu of each Number Slider.
