The ply2vrmesh command-line utility can convert .ply, .obj, .bin, .geo, .bgeo, .hclassic, .bhclassic, .abc and .vrscene files to .vrmesh files for rendering with V-Ray through V-Ray Proxy Objects.
width
5%
width
33%
UI Paths
width
90%
Windows
C:\Program Files\Chaos Group \V-Ray\Maya 20nn 20xx for x64\vray\bin\ply2vrmesh.exe
The converter works with most of the popular .ply formats, both ASCII and binary, big-endian, or little-endian.
Inaddition to the geometric data (faces and vertices), the converter recognizes some of the most common additional channels such as diffuse surface color. Vertex colors are recognized if they are specified as "red", "green", and "blue" or "diffuse_red", "diffuse_green", and "diffuse_blue" vertex properties.
