UI Expand
expandedtrue
titleUI Path
width50%
File menu > Open Cosmos Browser
width50%
UI Text Box
typeinfo
Chaos Cosmos Library is also available from the Cosmos tab in the bottom expandable dock panel (: click the Cosmos () button and expand the panel)tab.
The Cosmos integration in the bottom dock panel offers slightly different workflows and limited features compared to the Cosmos Browser that is available from the File menu.
For more information, please check the Cosmos Tab page.
Chaos Cosmos Browser is part of the installation of Chaos Envision and does not require any other specific actions. You can access the downloadable content of the Chaos Cosmos Platform platform from within Chaos Envision after the installation is finished.
For more information on Chaos Envision installation, see the Installation page.
width55%
To start using the Chaos Cosmos content, please follow the steps below:
1. Go to the File menu and select the Open Cosmos Browser option to open the Chaos Cosmos Browser.
2. If you are not signed into your Chaos account, click the Sign in button. Then enter your Chaos credentials.3. Use the menu or the Search tab to find assets. You can additionally choose between different Categories. An option to show Downloaded assets only is also available.
The filters help you refine your search by date, popularity, color, and space.
width5%
width40%
width55%
Once you choose an asset, you have to download it. Hover over it and click the Download  button.
Another way to download an asset is to click on it and open it in a pop-up window. This reveals additional information such as the category/space/color of the asset and other details. Other connected assets can be filtered by clicking on any of the additional information parameters. Click the Download button to download the asset.
All downloaded assets are marked with Image Removed Image Added symbol. They are available in the Downloaded category.
UI Text Box
typetip
Any Cosmos asset can be marked as your favorite through the Like () button. Favorite assets are marked with  symbol and are available in the Likes category.
width5%
width40%
width55%
You can place downloaded 3D models either in the center or at a random place in the scene.
To import a 3D model into Envision, do one of the following:
  • Random place in the scene: Use dragging to the viewport. That This starts the component placement tool and allows you to place the asset wherever you want in the scene with proper surface alignment.
  • Center of the scene: Use the Import button to bring the asset into the host platform. The button places the asset at 0,0,0 of the coordinates system
UI Text Box
typetip
Placed 3D assets can be moved, rotated, and scaled, and have their visibility toggled on and off.
width5%
width40%
width55%
The Materials section contains an array of pre-made materials, such as wood, metal, glass and others. It also contains Decals, which can be used to simulate dirt or stickers on objects.
Once downloaded, materials can be imported via dragging onto a selected object. The imported material is visible in the Materials bottom paneltab.
Click the green arrow for two additional import options.
Use triplanar mappingEnables triplanar mapping on VRayBitmaps (when adding the material to a scene or selection).
Use real-world scale – Enables real-world scale mapping for VRayBitmaps (when adding the material to a scene or selection).
UI Text Box
typeinfo
When an option is enabled in this menu, a blue circle () indicates the custom setup is in effect for any further material imports.
width5%
width40%
Cosmos lights are imported as meshes in the Meshes filter tab of the Objects right-hand side paneltab.
HDRIs
Downloaded Chaos Cosmos HDRIs can be imported as Environment texture. To assign an HDRI, click Import or drag it drag it in the scene and it will automatically be assigned to the Sky tabsubtab.
Animated Assets
Some vegetation assets have an animation indicatorshowing that the assets are animated and the animation is available in Chaos Envision only.
Note that the Wind animation option must be enabled from Right panel > Environment tab > Sky subtab to enable the animation.
Update Assets
width55%
Cosmos assets get updated over time. When an update is available, an update label appears.
You can download the new versions from within the Chaos Cosmos Browser. Click on the labeled asset to open a popup window and click the Download now update text in the bottom.
width5%
width40%
See also:
Thumbnailspagesettings
ThumbnailOverlayRectangleColour0,0,0
ThumbnailOverlayRectangleOpacity0.5
ThumbnailBGImageHeight100px
ThumbnailOverlayOpacity0
ThumbnailSubTextSize13px
ThumbnailTextColourWhite
ThumbnailTitleTextSize22px
ThumbnailOverlayRectangleHeight80%
ThumbnailOverlayRectangleBottomPadding10px
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1000px
Columns1repeat(3, 1fr)
Columns1width1540px
Columns2width1290px
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
CardPageLinkCosmos Tab
Cosmos Tab
Textboxcard
CardPageLinkMaterials Tab
Materials Tab
Textboxcard
CardPageLinkObjects Tab
Objects Tab
