To start Interactive Rendering in a floating window, go to the "Corona" menu at the top of the Cinema 4D interface and click "Interactive Rendering":
Image RemovedImage Added
Corona Interactive Rendering in a floating (undocked) window.
width45%
Corona offers drawing and rendering of regions in the Virtual Frame Buffer.
Select the "Region" mode and draw a region wherever you want. Click and Drag Drag to add new regions. Ctrl + Drag on the region border enables ''Fuzzy" region mode, in which the regions are seamlessly blended into the rest of the image.
By clicking and holding over the Region button you can also toggle all regions on and off, and remove all existing regions.
width5%
width50%
width5%
width30%
Region mode
width30%
Multiple Regions mode
width30%
Fuzzy Region mode
width5%
