This page provides information on the Denoiser Render Element.
Section | |||||||||||||||||||||||||||||||||||||||
UI Path
||V-Ray Asset Editor|| > Settings > Denoiser
Anchor | ||||
Example: Denoising Presets
The example below illustrates how VRayDenoiser works using the presets. A purposely noisy render was set up using the Progressive Image Sampler Type with Render Time set to only 3 minutes to leave plenty of noise in the render.
Section | |||||||||||||||||||||||||||||||||||||||||||||||||
Denoising Animations
When denoising animations, it is recommended to use the Standalone Denoiser Tool. Unlike the denoiser integrated in the UI, the standalone tool can do frame blending for animations, which reduces flickering. The integrated denoiser only works on the rendered frame and does not take the next and previous frame(s) into account, like the standalone tool does.
