width60%
The Outline Override material settings are organized in Basic and Advanced modes. You can switch the mode from the toggle button under the Preview Swatch or globally from the Configuration rollout of the Settings tab.
An Add Layer and Add Attribute buttons are provided for some V-Ray materials, including Outline Override. You can select an additional layer that can add up to the appearance of the material. For more information, see theAdd Attribute and Add Layer sections.
UI Text Box
typetip
Holding down Ctrl while having the Add Attribute or Add Layer menu open, allows selecting multiple entries without closing the dropdown.
The context menu of the Color slot provides options to Copy and Paste, as well as to Reset the color.
A Reset option is provided in the context menu of each Number Slider. You can reset the slider value to the default one.
width5%
width35%
Image Removed
Image Added
Base
width60%
Base – Specifies the base layer material.
width5%
width60%
width25%
width50%
Before after
afterLabelon
darktrue
beforeLabeloff
Panel
borderStylenone
Panel
borderStylenone
width25%
Viewport Binding
width60%
Viewport Texture
The selected texture is displayed in the viewport.
width5%
width35%
Image Added
Override Control
width60%
Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Settings.
width5%
width60%
Attributes
The Attributes available for the Outline Override material are as follows.
Expand
titleTranslucency
Translucency
Multiexcerpt include
SpaceWithExcerptVRHINO
MultiExcerptNameTranslucency Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Translucency Attributes
Expand
titleBump
Bump
MultiExcerptNameBump Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Bump Attributes
Expand
titleOutline
Outline
MultiExcerptNameOutline Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Outline Attributes
Expand
titleDisplacement
Displacement
MultiExcerptNameDisplacement Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Displacement Attributes
Expand
titleRaytrace Properties
Raytrace Properties
MultiExcerptNameRaytrace Properties Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Raytrace Properties Attributes
Expand
titleOverride
Override
MultiExcerptNameOverride Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Override Attributes
Expand
titleMaterial ID
Material ID
MultiExcerptNameMaterial ID Attribute
DisableCachingtrue
PageWithExcerptVRHINO:Material ID Attributes
Layers
The Layers available for the Outline Override material are as follows.
VRay Mtl
Emissive
Diffuse Coat
Reflective Coat
Flakes 2
Stochastic Flakes
