width55%
The V-Ray Hair Sampler is a utility node that provides extra output attributes that can be used when shading hair.
This texture allows you to map color, incandescence, and transparency along the length of a hair strand, as well as the ability to randomize such properties on a per-strand basis to create stunning hair looks.
UI Path: ||Node Editor|| > Shader > Add > Texture Utilities > V-Ray Hair Sampler
width5%
width40%
