VRayMultiSubTex controls the transparency of an object/Get ID from ID generator tex. The ID gen. tex. is a VRaySamplerInfoTex with a Type - Transparency level. The VRayMultiSubTex is used in the Opacity slot of the material and the actual transparency is controlled by the value of the color in the ID 0 Slot. The Default Slot is black, meaning all the range from 0 to 255 will be used. The difference from the standard opacity is that here, we can't see the back faces of the object.
UI Button
colorblue
icondownload
titleSample Scene
urlhttps://drive.google.com/uc?export=download&id=160wq1qydoL89HXINsqLBXDeh5wafRQBd
width30%
width40%
Image slider
Panel
borderStylenone
IDGenTex_Slots1_DefSlot-V0_ID0-V255
ID Generator Tex: Slots = 1; Default Slot = V0; ID0-V255
Panel
borderStylenone
IDGenTex_Slots1_DefSlot-V0_ID0-V192
ID Generator Tex: Slots = 1;Default Slot = V0; ID0-V192
Panel
borderStylenone
IDGenTex_Slots1_DefSlot-V0_ID0-V128
ID Generator Tex: Slots = 1;Default Slot = V0; ID0-V128
Panel
borderStylenone
IDGenTex_Slots1_DefSlot-V0_ID0-V0
ID Generator Tex: Slots = 1;Default Slot = V0; ID0-V0
width30%
