This page provides information on how the latest version of V-Ray handles scenes saved with previous versions of V-Ray.
V-Ray 6 adds a number of rendering optimization features. However, for compatibility reasons, some features and workflows have been adjusted and are discussed in detail below.
V-Ray for SketchUp is not forward-compatible, meaning projects done with V-Ray 6 are not guaranteed to work with V-Ray Next or older versions. If a project is opened using an older V-Ray version than the one it was created with, a prompt message will offer wiping all V-Ray data to ensure file stability.
Lights
The Portal Light option in V-Ray Rectangle light is now a legacy option and is no longer exposed in the UI. This is done because with the introduction of the adaptive sampling for dome lights and environments, the Skylight portals are not needed anymore.
Starting with V-Ray 6, the V-Ray Preset Material Library is part of the Chaos Cosmos Browser. Materials that have already been downloaded with any earlier V-Ray version remain unchanged and can still be loaded as a custom folder.
Enscape Compatibility
Scenes set up using Enscape will now render in V-Ray. Materials and even the Enscape assets will be automatically handled by V-Ray providing a great starting point when transitioning from the Enscape design stage to the high-end visualization in V-Ray. For more information, go to Enscape Compatibility.
A new Contours Render Element is added. This render element stores a mask for both the global and individual material contours. It can be used for compositing. Note that Contours will only appear in a Contours render element and not in the RGB/Beauty image.
Textures
The Double-sided mode is hidden from the Texture Placement parameters. Double-sided mode can be controlled by material assignment of each individual face. The option is now handled entirely by SketchUp for more consistent results between the Viewport and V-Ray.
V-Ray Frame Buffer
Color Corrections saved as .vccglb files with V-Ray Next cannot be loaded in V-Ray 5.
Note that in order to work with V-Ray 5 builds, you need to have the proper License Server. For more information about the License Server, see Installing the License Server.
V-Ray 6 is the latest version that supports the import of V-Ray 2 models, components and materials.
Scatter Viewer In Previous SketchUp Versions
Here is what the Scatter Viewer used to look like in SketchUp 2022 an earlier versions. See the Scatter Viewport Preview Workflow for versions 2023 and later.
UI Paths
Section | |||||||||||||||||||||||||
Workflow
