UI Expand | |||||||||||||||||
All Scatter objects are located in the Objects tab > Scatter filter tab. All Scatter objects' parameters are accessible in the Details tab. |
Scatter Buttons
Section | |||||||||||||||||||||||||||||||||
Scatter Tabs
Scatter Setup
Select the Cosmos models you want to scatter and drop them onto the Models section of the Scatter layer settings.
Models can be scattered either over a surface, or over a spline. For more information, check the Scatter Workflows article.
Scattering over a surface
Scattering over a spline
Randomization
Targets Tab
Allows selecting new objects (primitives or splines) on which the instances are scattered.
Exclusion Areas Tab
Allows picking objects (primitives or splines) which define the exclusion areas. The models are scattered everywhere on the target objects, except in the areas where the objects in the Exclusion Areas list are located. This option is useful, for instance, for removing instances of grass/trees from areas where a house needs to be located.
Examples
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Detect Collisions
Anchor | ||||
Anchor | ||||
See also:
Thumbnailspagesettings | ||||||||||||||||||
Responsivegridmacro | ||||||||||||
