Spacing – (Available for Scatter over spline mode only) Determines the spacing between instances in meters. See the Spacing example below. Jitter – (Available for Scatter over spline mode only) Randomly jitters instances along the spline. Each instance has Spacing applied on both its sides, except the instances at the end of the spline. The Jitter value is divided between those two Spacings. Offset – (Available for Scatter over spline mode only) Determines what percentage of the Spacing the instances are offset in one direction of the spline. When set to 100%, all instances replace the one after them, as the offset is equal to the whole value of the Spacing. See the Offset example below. Follow spline – (Available for Scatter over spline mode only) Determines how scattered instances are oriented along the spline. Assigning a value of 100%, makes instances follow the spline and are oriented along the local tangent direction. Detect collisions – Prevents the scattered models from colliding with each other. See the Detect Collisions example below. Models – The list of models used in the currently selected Scatter. Click on a model and move the slider to set its Frequency. See the Frequency example below – Remove either the selected models, or all the models if none are selected.
You can double-click on a layer to change its name. |
