width50%
Rendering
FeatureV-RayV-Ray GPU
Cinema 4D Team Render 6(tick)(tick)
Stereoscopic Rendering(tick)(tick)
Resumable Rendering(tick)(tick)
Viewport Interactive Rendering(tick)(tick)
Geometry
V-Ray Proxy(tick)(tick)
V-Ray Scene 3(tick)(tick)
Geometry tag(tick)(tick)
Object Properties tag(tick)(tick)
V-Ray Fur(tick)(tick)
V-Ray Clipper(tick)(tick)
(without Mesh mode)
Cinema 4D Floor(tick)(tick)
Renderable Spline tag
(tick)
(tick)
Perfect Sphere(tick)(tick)
V-Ray Enmesh(tick)(tick)
V-Ray Decal(tick)(tick)
V-Ray Particles
(tick)
(tick)
Chaos Scatter
(tick)
(tick)
User Data Tag
(tick)
(tick)
Render Elements
Preset: Back to Beauty(tick)(tick)
Atmospheric Effects(tick)(tick)
Background
(tick)
(tick)
Bump Normals
(tick)
(tick)
Caustics
(tick)
(Production mode)
(error)
Coat Specular(tick)(tick)
Coat Filter(tick)(error)
Coat Glossiness(tick)(error)
Coat Reflection(tick)(tick)
Coverage
(tick)
 (error)
Cryptomatte
(tick)
(tick)
Denoiser
(tick)
(tick)
Diffuse
(tick)
(tick)
Extra Tex(ture)
(tick)
(tick)
GI
(tick)
(tick)
LightMix(tick)(tick)
Light Select
(tick)
(tick)
Lighting
(tick)
(tick)
Material ID(tick)(tick)
Material Select(tick)(error)
Matte Shadow(tick)(error)
Metalness(tick)(error)
Multi Matte(tick)(error)
Multi Matte ID(tick)(error)
Normals(tick)(tick)
Object ID(tick)(tick)
Object Select(tick)(error)
Raw Coat Filter(tick)(tick)
Raw Coat Reflection(tick)(tick)
Raw Sheen Filter(tick)(tick)
Raw Sheen Reflection(tick)(tick)
Raw GI(tick)(error)
Raw Light(tick)(error)
Raw Reflection(tick)(error)
Raw Refraction(tick)(error)
Raw Shadow(tick)(error)
Raw Total Light(tick)(error)
Reflect IOR(tick)(error)
Reflection Filter(tick)(tick)
Reflection Glossiness(tick)(error)
Reflection Highlight Glossiness(tick)(error)
Refraction(tick)(tick)
Refraction Filter(tick)(tick)
Refraction glossiness(tick)(error)
Render ID
(tick)
(tick)
Sheen
(tick)
(tick)
Sheen Glossiness
(tick)
(tick)
Sheen Filter
(tick)
(tick)
SSS(tick)(tick)
Sample Rate(tick)(tick)
Sampler Info(tick)PARTIAL8
Self Illumination(tick)(tick)
Shadow(tick)(tick)
Toon(tick)(error)
Toon Lighting(tick)(error)
Toon Specular(tick)(error)
Velocity(tick)(tick)
Z Depth(tick)(tick)
Textures 10
FeatureTypeV-RayV-Ray GPU
VRayAColorOPClassic(tick)(tick)
VRayBitmapClassic+Node(tick)(tick)
VRayC4DBakeClassic(tick)(tick)
VRayCurvatureClassic+Node(tick)(tick)
VRayDirtClassic+Node(tick)PARTIAL
VRayDistanceClassic+Node(tick)(tick)
VRayFalloffClassic+Node(tick)(tick)
VRayFresnelClassic+Node
(tick)
(tick)
VRayHairSamplerClassic+Node
(tick)
(tick)
VRayLayeredClassic+Node(tick)(tick)
VRayMixClassic+Node
(tick)
(tick)
VRayMultiSubTexClassic+Node
(tick)
(tick)
VRayNormalMapClassic+Node
(tick)
(tick)
VRayOCIOClassic+Node
(tick)
(tick)
VRayRampClassic+Node
(tick)
(tick)
VRaySamplerInfoClassic+Node
(tick)
(tick)
VRaySkyClassic(tick)(tick)
VRaySoftboxClassic+Node(tick)(tick)
VRayTriPlanarClassic+Node
(tick)
(tick)
VRayUVWChannelClassic+Node
(tick)
(tick)
VRayUVWRandomizerClassic+Node(tick)
PATIAL
(Except TriPlanar texture)
VRayUserColorClassic
(tick)
(tick)
VRayUserScalarClassic(tick)(tick)
VRayUserIntegerClassic(tick)(tick)
CellularNode(tick)(tick)
CheckerNode(tick)(tick)
Color ArithmeticNode(tick)
(tick)
Color ChannelNode(tick)(tick)
Color CorrectionNode(tick)(tick)
ColorNode(tick)(tick)
Color RangeNode(tick)(tick)
Color to FloatNode(tick)(tick)
Color to UVWNode(tick)(tick)
Combine ColorNode(tick)(tick)
Compose ColorNode(tick)(tick)
Bump to GlossinessNode(tick)(minus)
EdgesNode(tick)(tick)
Float ArithmeticNode(tick)(tick)
Float to ColorNode(tick)(tick)
Invert FloatNode(tick)(tick)
InvertNode(tick)(tick)
LuminanceNode(tick)(tick)
Maxon NoiseNode(tick)(tick)
Noise MaxNode(tick)(tick)
Particle SamplerNode(tick)PARTIAL
RemapNode(tick)(tick)
RGB to HSVNode(tick)(tick)
SmokeNode(tick)(tick)
SplatNode(tick)
Status
colourYellow
titlebaked
StuccoNode(tick)
Status
colourYellow
titlebaked
TilesNode(tick)
Status
colourYellow
titlebaked
UVW ObjectNode(tick)(tick)
UVW Place 2DNode(tick)(tick)
UVW ProjectionNode(tick)(tick)
UVW to ColorNode(tick)(tick)
UVW TransformNode(tick)(tick)
Value 5Node(tick)(tick)
Vector ProductNode(tick)(tick)
Vertex ColorNode(tick)(tick)
Overrides
Material Override(tick)(tick)
Effectors
MoGraph Shader(tick)(tick)
width50%
Camera
Feature
V-Ray
V-Ray GPU
Cinema 4D Camera
PARTIAL
(Except: Dimetric, Military, Gentleman, Frog, Bird)
PARTIAL
V-Ray Camera
(tick)
(tick)
Special Object
Cinema 4D Stage 4(tick)PARTIAL
Mograph Objects
Cloner(tick)PARTIAL
Matrix(tick)PARTIAL
Cinema 4D Shaders
Standard Material 11
PARTIAL
PARTIAL
Color
(tick)
(tick)
Fresnel
PARTIAL
PARTIAL
Gradient
PARTIAL
(Except Turbulence)
PARTIAL
(Except Turbulence)
Noise(tick)(tick)
Colorizer
(tick)
(tick)
FilterPARTIALPARTIAL 2
Fusion
PARTIAL
(Except: Soft Light, Dodge, Burn,
Darken, Levr blend modes)
PARTIAL
LayerPARTIALPARTIAL
Posterizer
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Effects
Ambient Occlusion
(error)
(error)
Backlight
(error)
(error)
ChanLum
(error)
(error)
Distorter
(error)
(error)
Falloff
(tick)
(tick)
Lens Distortion
(error)
(error)
Lumas
(error)
(error)
Normal Direction
(error)
(error)
Normalizer
(error)
(error)
Pixel
(error)
(error)
Projector
PARTIAL
(Except: Flat, Cubic, Frontal, Spatial,
Shrink Wrapping)
PARTIAL
Shrink Wrapping)
Proximal
(error)
(error)
Ripple
(error)
(error)
Spectral
(error)
(error)
Spline
(error)
(error)
Subsurface Scattering
(error)
(error)
Terrain Mask
(error)
(error)
Thin Film
(error)
(error)
Variation
(error)
(error)
Vertex Map(tick)(tick)
Weathering
(error)
(error)
MoGraph
Beat Shader
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Camera Shader
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Color Shader
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Multi Shader
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Sketch and Toon
Art
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Cel
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Hatch
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Spots
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Surfaces
Brick
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Checkerboard(tick)(tick)
Cloud
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Cyclone
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Display Color
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Earth
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Fire
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Flame
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Formula
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Galaxy
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Marble
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Metal
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Pavement
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Planet
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Rust
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Simple Noise(tick)(tick)
Simple Turbulence
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Starfield
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Stars
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Sunburst
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Tiles
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Venus
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Water
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Wood
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Moves Face Shader
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Polygon Hair
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Substance Shader
Status
colourYellow
titlebaked
Status
colourYellow
titlebaked
Particle Systems Channels
Particle TypeChannel
Thinking Particles GroupParticle ID
Position
Velocity
Radius
Color
Age
Transformation
X-ParticlesParticle ID
Position
Velocity
Radius
Color
Age
Lifespan
Transformation
Cinema 4D Emitter (Legacy)Particle ID
Position
Velocity
Radius
Age
Transformation
MoGraph Generators (Matrix, Cloner)Particle ID
Position
Radius
Color
Transformation
Cinema 4D Emitter13
Particle ID
Position
Velocity
Radius
Age
Transformation
Instance Rotation
Redshift Shaders 9
Texture(tick)(tick)
Wireframe(tick)(tick)
Maxon Noise(tick)(tick)
Curvature(tick)(tick)
Fresnel(tick)(tick)
Ramp(tick)(tick)
Bump Blender
(tick)(tick)
Material (Legacy)(tick)(tick)
Ambient Occlusion(tick)(tick)
Scalar Ramp(tick)(tick)
Color Constant(tick)(tick)
Color Maker(tick)(tick)
Color Splitter(tick)(tick)
Incandescent(tick)(tick)
Color Layer(tick)(tick)
Material Layer(tick)(tick)
Material Blender(tick)(tick)
MoGraph Shaders 12
Feature
V-Ray
V-Ray GPU
Multi Shader(tick)(tick)
Color Shader(tick)(tick)
Tags
Compositing(tick)(tick)
