This page provides information about the installation of actors in Chaos Anima.
Installing Purchased Actors
width40%
All the Metropoly® characters are available in the native Anima format (*.y) and, once purchased, you can download them from your user control panel under the Order or the Download sections.
width5%
width55%
Image Added
width40%
Both the purchased and the subscription models will be downloaded into the “Purchases” folder that is defined in the preferences panel (anima® icon menu > preferences).
width5%
width55%
Image Added
width40%
To edit the path, click on the 3 dots icon at the right side of the setting and choose the new location:
There are 4 ways to install the actors:
  1. Direct Download from Anima (you must be logged in with your account).
  2. Download Auto-detection: anima® will automatically detect and install all the new *.y files found in the windows “downloads” folder. So If you download a purchased collection or any other compressed model, you’ll need to extract it inside that same folder for anima® to detect it.
  3. Manual copy: you can install them by manually copying only the “*.y” files directly in the “\Purchases\models” (Posed, Ambient, Rigged) or the “\Purchases\streams” (4D models) folder.
  4. Manual drag’n’drop: Drag and drop those *.y files to the anima viewport. Please note that this must be done directly with the *.y files, not the folders or the zipped packages.
UI Text Box
typenote
NETWORK RENDERING:  On anima® version 4.1.1 or older, the purchases folder must be placed in a network drive and accessible from the Render Nodes. However, this is not needed anymore for newer versions of anima® (4.5.0 or newer) because now the nodes use a resource cache that is placed inside each anima® project folder.
width5%
width55%
Image Added
Direct Download from Anima Library
width40%
The integration of the website store and account login brings another great feature, while you’re online, the system will automatically keep all your content up to date and notify you of any available content updates.
First, you must log in to your AXYZ design user account:
width5%
width55%
Image Added
width40%
Then, if there is some fix or improvement on any of your actors, you will know right away and you will be able to update it with just one click.
width5%
width55%
Image Added
width40%
Also, since version 4.0 you can select and download multiple actors at the same time, they will be managed in an automatic download cue directly from inside the anima® library. You can do it using the right-click over any of the selected actors and then choosing either download or update, depending on the case.
width5%
width55%
Image Added
width40%
They will be downloaded one after the other and installed automatically in your library right away, without needing to restart anima®. Also, any plugin instance will be notified through the alive™ connection, so it won’t be necessary to restart your 3D application anymore.
width5%
width55%
Image Added
width40%
Take a look at this video tutorial to see the new download process in action.
width5%
width55%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/UAvek03rpOg?si=VtqdBXAYgKsSjISd&start=638" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Auto-Detection
width40%
If you have downloaded your actors to your downloads folder, next time that you open anima®, a pop-up window will appear asking if you will like to install the new assets.
Note that anima® will automatically detect and install all the new *.y files found in the windows “downloads” folder. So if you downloaded a purchased collection or any other compressed model, you’ll need to extract it inside that same folder for anima® to detect it.
width5%
width55%
Image Added
width40%
After clicking “Yes” another window will confirm that the product has been successfully imported.
width5%
width55%
Image Added
width40%
The new actor(.y) will be automatically Installed in the Purchases Folder. Depending on the type of model, it will be installed in the “models” (Posed, Ambient, Rigged) or the “streams” (4D models) subfolder.
width5%
width55%
Image Added
width40%
The thumbnail of the actor will be displayed in the actors’ library under the purchased tab in Editing mode and in the Rigged or ready-posed tabs in Drawing mode, depending on the model.
If you have downloaded your actors into a different folder, you can either drag them to the viewport or copy the files directly into the purchases folder.
width5%
width55%
Image Added
Manual Copy
width40%
You can install them by manually copying the “*.y” files directly in the corresponding “models” (Posed, Ambient, Rigged) or the “streams” (4D models) subfolder of the “Purchases” path that you have defined in your anima® Preferences, here:
width5%
width55%
Image Added
Manual Drag & Drop
Drag and drop the downloaded (and extracted if necessary) anima® format *.y files to the viewport and the actor will be automatically copied to your Purchase folder and will show up in the library.
Please note that this must be done only with the anima® native format files (*.y), not folders nor zipped packages nor any other file format.
