width57%
Chaos Scatter is a powerful instancing and distribution tool that allows you to easily populate scenes with selected objects. This is especially useful for outdoor scenes that need to be filled with greenery, rocks, grass etc. Scatter allows for great control over the instances as well - you can customize and randomize your scene easily.
UI Path: ||V-Ray|| > Chaos Scatter
width40%
Image RemovedImage Added
width60%
width5%
width38%
