This page provides information on the Chaos Cloud Collaboration options.
width50%
Chaos Cloud collaboration helps you share your work with your team and your clients. Simply invite them to review your images and share their feedback. This speeds up reviews, so you can get your projects done faster.
Signing into Chaos Cloud Collaboration using your Chaos credentials is required once. After that, you are automatically signed in every time you open the Collaboration window.
For more information
, see the Collaboration page.
width5%
width45%
HTML
<iframe width="560" height="315" src="https://www.
youtube.com/
embed/Cf7Tw0jTHMc?si=70hjRIGd3IDR7ST0" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
UI Paths
width15%
width30%
||V-Ray menu|| > Chaos Collaboration
Image Added
||VFB|| > Save current channel > Upload image to Chaos Collaboration
Image Added
width10%
width30%
||VFB|| > File > Upload image to Chaos Collaboration
Image Added
||VFB|| >Render History > (Right-click on any previously saved image) > Upload image(s) to Chaos Collaboration
Image Added
width15%
Workflow
width50%
Fancy Bullets
typecircle
  • Render your scene in the V-Ray Frame Buffer.
  • Open the Chaos Collaboration window. You can open it from the VFB, or from the V-Ray menu.
  • If you have not signed into Chaos Cloud yet, you will be prompted to do so now. Signing into Chaos Cloud
UI Path
V-Ray menu > Chaos Cloud Collaboration
Workflow
WIP
The Collaboration tab provides a collaboration tool for sharing your work with other users. You can upload images from the VFB to the Chaos Cloud Collaboration where other users can add comments and annotations.
  • using your Chaos credentials is required once. After that, you are automatically signed in every time you open the Collaboration tab.
  • Click anywhere in the window to upload to Chaos Cloud.
  • Select upload destination. A default project folder and project name are assigned, but you can customize them at this step. You can also add additional images for upload from the button.
  • When the render(s) are uploaded, you can choose to continue uploading or to view your renders in Chaos Cloud.
You can upload other images via the Upload image to Chaos Collaboration Image Modified button
Automatically, there is a default project folder where the images are uploaded to Chaos Cloud Collaboration. You can create multiple projects and folders from the browser.
width5%
width45%
Image Added
Virtual Tours
width50%
After Uploading your render to Chaos Cloud, you can showcase it and create virtual tours to allow others to "walk around" your scene. For more information, visit the dedicated Chaos Cloud Collaboration page.
width5%
width45%
Image Added
Window Options
width50%
The Collaboration tab has several sections: Upload files containing a list of images for upload, Recent containing recent projects, and Browse with locations where the images are uploaded.
Image Modified – Deletes the current image from the upload list.
Image Modified – In the Upload files, uploads the current image in the VFB to Chaos Cloud Collaboration. In Browse, creates a new project or folder.
Image Modified – Renames the Upload file.
Upload
file – Uploads the image(s) to Chaos Cloud Collaboration in the selected project or folder.
It is also possible to directly drag the images from the Explorer to the Collaboration tab.
width5%
width45%
Image Added
After Upload
width50%
New upload – Clears the Collaboration tab and prepares it for the new upload of images.
Open in
CloudOpens the uploaded images in the Chaos Cloud
Browser.
width5%
width45%
Image Added
Window After Upload
