Enabled – – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawRefraction.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mappingManagement rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
