Square Enix © Goodbye Kansas
« Previous Version 11 Current »
This page gives some basic details about the Raw Refraction Render Element and how it is used in compositing.
The Raw Refraction Render Element is a color image that stores refraction information calculated from materials' refraction values in the scene. Surfaces with no refraction values set in their materials will contain no information in the render element and therefore will render as black.
In comparison, the Refraction Filter Render Element (vrayRE_Refraction_Filter) is a render element that indicates varying degrees of refraction in the scene through brightness values in the image. Multiplying these two render elements together produces the Refraction Render Element (vrayRE_Refraction) .
 To properly calculate the Raw Refraction Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
Attributes
Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawRefraction.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
Common Uses
The Raw Refraction Render Element is useful for changing the appearance of refractive elements after rendering in a compositing or image editing application. Below are examples of possible uses.
Original Beauty Composite
Raw Refraction Render Element with added contrast
Tinted Raw Refraction Render Element with added contrast
Refractions with more contrast
Tinted Refractions with more contrast
Underlying Compositing Equation
vrayRE_Raw_Refraction x Refraction Filter = Refraction
  • To properly calculate the refraction information in the Raw Refraction and Refraction Filter Render Elements, the Refraction Render Element must also be rendered at the same time, even if it's not going to be used in the compositing process. Doing so enables all the refraction information to be included in the rendering calculations.
  • There is initial support for Raw Refraction render element on V-Ray GPU.
