Square Enix © Goodbye Kansas
This page provides information on the Color Management rollout of the Render Settings.
Color mapping (also called tone mapping) can be used to apply color transformations on the final image colors. Sometimes an image can contain a higher range of colors that can be displayed on a computer screen. Color mapping has the task of re-mapping the image values to be suitable for display purposes.
UI Path: ||Render Settings window|| > VRay tab > Color management rollout
Rendering color space – Specifies the color space to be used for rendering. It affects Sun/Sky, temperature color controls, and texture color conversion. For VFB to properly display ACEScg renders, use the respective OCIO config. The following options are available:
From Maya Preferences
Scene-linear Rec 709/sRGB
ACEScg – For more information on ACEScg workflow with V-Ray, see the ACEScg Workflow Setup page.
