Align
aligncenter
Image_comparison_slider
AddButtonsfalse
LabelBeforeoff
width60%
LabelAftermax altitude 50000
height60%
Falloff Curve
Status
subtletrue
colourBlue
titleV-Ray 7 Beta
width55%
The Falloff Curve specifies the density of the scattered objects depending on their altitude.
Lowering the point on the left side of the curve results in lowering the density of the objects closer to the minimum altitude range. Lowering the point on the right side of the curve results in lowering the density of the objects close to the maximum altitude range.
The Expand button opens the Falloff Curve in a separate window.
width5%
width40%
