Section | |||||||||||||||||||||||||||
Look At
Status | ||||||
Example: Look At
In this example, the sunflower objects are scattered along a plane and the Look At option is enabled. The VRaySun is assigned as the Target object, and it is moved along the sky as if it was setting over the horizon. The Horizontal option is enabled, allowing the sunflowers to rotate more realistically. Slide through the images to see the movement of the sunflowers.
Section | ||||||||||||||||||||||||||||||||||||||||||||||
Scale
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
