Comment: added channel type
This page provides information about the Coverage Render Channel in V-Ray for Blender.
HideElements
cssselector#tocHorizontal, #tocVertical
width50%
The Coverage Render Channel holds anti-aliasing data based on the Render ID Render Channel. When the Coverage Render Channel is multiplied by the Render ID Render Channel in compositing, it adds anti-aliasing to the Render ID channel, providing a quick object mask.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Utility > V-Ray Coverage
width5%
width45%
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAftercoverage channel
height80%
Properties
width50%
Enable Deep Output –  – Includes this render element in deep images.
width5%
width45%
Image Added
