Next, make sure you have an active V-Ray License, by either installing the online license server on your computer, or by connecting to a license server on your network. Each render server will need access to a V-Ray Render Node license. This process is made easy with the V-Ray Online Licensing System by loading http://localhost:30304/#/ (or use the IP address of the computer running the licensing system, with the port 30304). For more details on this process, please see the Manually Change Changing the Product License Server IPSetup page.
width25%
width50%
Panel
borderColorgray
borderStylesolid
width25%
Cross-platform render jobs are possible with V-Ray. For example, you can start a rendering from a Windows machine, and distribute to any combination of render servers running on Linux, macOS andmacOS and/or Windows to join the rendering job, as long as they are running their respective render server application. Any OS can originate arender a render as the render client, or receive a render job as a render server.
