Chaos Cosmos Browser is part of the installation of Chaos Envision and does not require any other specific actions. You can access the downloadable content of the Chaos Cosmos platform from within Chaos Envision after the installation is finished.
For more information on installing Envision installation, see the Installation page.
width55%
To start using the Chaos Cosmos content, please follow the steps below:
1. Go to the File menu and select the Open Cosmos Browser option to open the Chaos Cosmos Browser.
2. Use the menu or the Search tab to find assets. You can additionally choose between different Categories. An option to show Downloaded assets only is also available.
The filters help you refine your search by date, popularity, color, and space.
3. Perform various actions with the Cosmos assets such as downloading, importing, deleting, and updating with the Cosmos assets. See the sections below for more information.
UI Text Box
typetip
You can perform actions on multiple assets simultaneously using Multi-Selection Mode. Click the Multi-Selection Mode button () to enable it, then select multiple assets. Any action you perform will be applied to all selected assets.
Currently, it is not possible to import multiple assets.
width5%
width40%
