Envision 0.
3.
0
Beta Release, Update 23
Date - January 24February 26, 2025
UI Button | ||||||
UI Button | ||||||||
New Features
- Add support for Sketchup UVW scale attribute during import.
Improvements
- Updated the timeline play-head design.
- Color Corrections: when the type is set to Ampas, non applicable parameters are hidden.
- Color Corrections: highlight burn is disabled when Filmic tone-map is on as it is not applicable in that case.
- Disabled Seams blend of textures when Make Seamless is disabled.
Crash Fixes
- Failure to detect dedicated GPU leads to crash and Lavina renderer issues.
- GPU device instance suspension, system ran out of resources leads to crash.
- Crash when trying to render a simple scene.
- Crash after texture assignment on enhancements and tweaking of properties (regression).
- Material foliage no longer works (regression).
- Assert - Stack.h Line: 526, application close during asset download (conditional).
Big Fixes
- Mix top-material cosmos discovery blocked by active search filter.
- Scatter layer model list gets squashed after editing (regression).
- HDRi assignment discovery blocked by active filters (regression).
- Camera gizmo is not updating when child constraint is transformed (regression).
- Details panel buttons get cropped with high DPI scaling (conditional).
- Crowd generation overrides active actor paths of other crowds (regression).
- Scatter over line preset cannot be applied on spline target.
- Light gizmo not updating when child constraint is transformed (regression).
- Layer material selection remains active during pick top mix operation.
- Duplicate plugin names in multiple scenes conflict.
- Favorites category entry not updating properly while selected (conditional).
- Cosmos search filter discovery resets once category is changed (conditional).
- Variants marked as favorite are not discoverable in favorites section (conditional).
- Cosmos buttons (3d, materials, hdri) not linking back to the parent category.
- Scatter layers cannot be renamed (regression).
- Onboarding screens overlapping on document load (conditional).
- Onboarding screen buttons are misaligned/spacing issues.
- Select Material process cannot be cancelled in Full-Screen mode.
- Escape to revert for material picker no longer works (regression).
- UI locked when all three onboarding screens are present (regression).
- Cosmos Spline presets cannot be dragged on viewport splines.
- Onboarding warning screen warning points to invalid location (conditional).
- Font scale/crop issues with resolution indicator in viewport overlay & scene stats (regression).
- Scatter layers cannot be removed/deleted (regression).
- Cosmos categories labels should not be cut but positioned on two rows.
- Preferences window is still labeled as Application Settings.
- Full-screen button highlights remain active when exiting/entering mode (conditional).
- Angle to up vector not working for newly added scatter layers (regression).
- Variant assets missing numbering in their tooltip.
- Scatter instance generation gets triggered on material hover.
- User getting crashes in Envision.
- Material displacement no longer works (regression).
Envision 0.2.2
Date - January 24, 2025
Cosmos
- Added marking assets as favorite in the bottom dock and filter by favorite.
- Improved categories browsing with buttons and category path.
- Added support for 4D characters via Cosmos.
- Added the ability to import scatter presets from Cosmos.
- Added support for Cosmos assets with variants.
- Cannot render still image while animation is running.
- Fix issue with drag and drop actor in crowd list.
- Proxy(GeomMeshFile) scale is not imported correctly.
- Invalid mpeg output with specific aspect ratios.
- Bind character to spline path leads to wrong transforms.
- Scatter still visible when hidden.
- Can not pick dummy as look at target.
- SVG icons are pixelated on systems with DPI scaling.
Crash Fixes
- Prevent out of memory issues when exporting video with resolution above 7680(8k).
- Failure to detect dedicated GPU leads to crash and renderer issues.
