« Previous Version 6 Next »
Envision 0.2.2
Beta Release, Update 2
Date - January 24, 2025
Sign up for Chaos Envision Beta
Download Chaos Envision Beta
Cosmos
  • Added marking assets as favorite in the bottom dock and filter by favorite.
  • Improved categories browsing with buttons and category path.
  • Added support for 4D characters via Cosmos.
  • Added the ability to import scatter presets from Cosmos.
  • Added support for Cosmos assets with variants.
Functional
  • Added full screen mode for presenting.
  • Added “Rounded corners” Material enhancement.
  • Added quality presets for viewport rendering.
  • Improved map button behavior.
  • Added reset buttons restore from linked scene.
  • Added a button for material editing.
Miscellaneous
  • Improved consistency of the reset buttons.
  • Improved UI for the Cosmos tab.
  • Improved UI of scrollbar size and spacing.
  • Added tooltips for Filter by scene and revert transformations.
  • Various UI adjustments
Bug Fixes
  • Crash after texture assignment and then accessing material properties.
  • Crash when accessing material filter by scene with no document loaded in.
  • Crash upon selecting all nodes.
  • Downloaded only checkbox has extended focus/hover trigger.
  • Excessive noise/shimmering or ghosting of characters or vegetation affected by wind.
  • "Downloaded only" cosmos option doesn't update properly after a filter is applied.
  • Slow loading of embedded material thumbnails on scene load.
  • Non-consistent details panel show/hide behavior when spline tool is active or a spline control point is added.
  • 4d Character texture/material flickers during animation playback.
  • Camera pivot/gizmo flickering during animation.
  • UI lock/freeze when simultaneous asset download takes place.
  • Incorrect animated actor orientation/facing when scattered along surfaces.
  • Cosmos HDRI selected from preview not working when mix material is used.
  • Scatter layer properties cannot become unique after the node is duplicated.
  • Invalid actor speed property range.
  • Release build import failure for HDRIs.
  • Render output progress-bar is not indicative of the actual rendering process.
  • Regressions & inconsistencies with material drag & drop onto multi material surfaces.
  • Incorrect displacement unit scaling.
Envision 0.2.1
Beta Release, Update 1
Date - December 18, 2024
Bug Fixes
  • Cannot render still image while animation is running.
  • Fix issue with drag and drop actor in crowd list.
  • Proxy(GeomMeshFile) scale is not imported correctly.
  • Invalid mpeg output with specific aspect ratios.
  • Bind character to spline path leads to wrong transforms.
  • Scatter still visible when hidden.
  • Can not pick dummy as look at target.
  • SVG icons are pixelated on systems with DPI scaling.
Crash Fixes
  • Prevent out of memory issues when exporting video with resolution above 7680(8k).
  • Failure to detect dedicated GPU leads to crash and renderer issues.
Envision 0.2.0
Beta Release
Date - December 3, 2024
Initial Beta
Import & Referencing
  • Link vrscene files created in any supported CAD tool.
  • Update the linked vrscene while preserving modifications.
Scene and environment variations
  • Create multiple variations of your scene and/or environment, and quickly switch between them.
Chaos Scatter
  • Scatter any Cosmos asset on surfaces or along lines.
Crowd simulation
  • Use animated characters from Cosmos to simulate walking crowds or stationary people.
Camera
  • Physical cameras with control over Aspect ratio, Two-point perspective and a flexible management.
  • Animate the camera with keyframes, along a spline and following a specific target.
  • Tweak color corrections per camera.
Build advanced animations
  • Timeline with dedicated tracks for scene variants, environment variants and cameras.
  • Different animation types for blending between variations.
Simple yet powerful material editor for editing and enhancing materials
