width50%
Let's start with the first render settings.
Connect the LowRes object node to the left input of the V-Ray BakerTool node.
UI Text Box
colorlight-yellow
iconwarning
typenote
 For this purpose, the lowRes object needs to have UVs and normals. The V-Ray BakerTool needs to be in Baking mode "Maps Baking".
width5%
width45%
width50%
The GenerateHeight node is a custom node that takes care of the following settings:
  • Extend Range - The value here should be higher than the biggest expected distance between the two meshes at any given point.
  • Clear_artifacts - This remap's purpose is to clear the closest places between the meshes, but because of the difference in the density, that will create an edgy effect. So let's leave the two most distal points (that's 0 and 1) and create a new point with Position 0.01. Set its Value to 0.
UI Text Box
colorlight-yellow
iconwarning
typenote
If the Position is bigger than 0.01, the displacement map will be badly clamped.
width5%
width45%
