This page describes the use of Batch Rendering in V-Ray for Revit.
The Batch Render option in V-Ray for Revit allows multiple renders to be rendered altogether with one button.
UI Text Box
typenote
Currently, batch rendering is supported only on the local machine and in the Cloud.
UI Path
width65%
||Revit Ribbon|| > V-Ray tab > Render panel (dropdown menu) > Batch Render
||Revit Ribbon|| > V-Ray tab > Render panel(dropdown menu) > Cloud Batch Render
width5%
width30%
How to Run Batch Rendering
width65%
1. From the drop-down menu of the View Selector, select the views you want to batch render.
width5%
width30%
width65%
2. Enable Auto-Save and specify the file path and type from Settings > Renderer tab > Auto-Save. Image options can be also changed. For more information, see Renderer.
width5%
width30%
Image Removed
Image Added
width65%
3. After the two steps above are completed, the batch rendering can be run.
UI Text Box
typenote
The rendering progress should be observed through the built-in progress bar at the bottom of the VFB.
UI Text Box
typewarning
The rendering process is cancelled, if Revit is closed during batch rendering.
width5%
width30%
How to Run Batch Rendering in Cloud
width65%
width5%
width30%
width65%
2. Now the batch rendering can be run. Click the Cloud Batch Render button. V-Ray will export the views as .vrscenes and send them to Chaos Cloud.
width5%
width30%
width65%
3. Sing in your Chaos Cloud account.
width5%
width30%
width65%
4. Submit your jobs to Chaos Cloud for rendering.
width5%
width30%
