width55%
The Filter/Layer presets tab holds the settings controlling the Filters and Layers tabs.
Preset path – Shows the path where the layer tree and filters presets are saved.
Browse for Layers path – Specifies a path to save the layer tree and filters presets.
Recent Recent – Shows a list of recently used locations for loading layer tree and filters presets.
Use own image Layer stacks when comparing in History – Disables the Layer panel, so that History A/B/C/D Compare uses the respective Layers setup of each image. When comparing the current render to one from the History panel, editing the Layers setup is available and is applied only to the current render. When comparing images from the History panel, the Layers panel is disabled and editing the Layers tree is not possible.
Ignore existing correction for the Filter thumbnails – When enabled, each Filter thumbnail previews the preset applied to the original image ignoring other correction layers present in the layers stack. When disabled, the complete layers stack is taken into account.
The default locations of the filters and layer presets are the following:
Windows: C:\Program Files\Chaos\V-Ray\Maya 20xx for x64\maya_vray\vfbpresets
Linux: /usr/Chaos/V-Ray/Maya20xx-x64/maya_vray/vfbpresets
macOS: /Applications/Chaos/V-Ray/Maya20xx/vray/VRay.app/Contents/vfbpresets
where xx is the Maya version.
width5%
width40%
