These pages provide information on how to get Chaos Anima up and running.
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1100px
Columns1repeat(3, 1fr)
Columns1width1740px
Columnsrepeat(4, 1fr)
Columns2width1290px
Before Installation
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
alignleft
classdashboard
Textboxcard
PageToInclude
System Requirements
CardPageLinkSystem Requirements
System Requirements
Check if your hardware matches the minimum requirements to run Anima.
Textboxcard
PageToIncludeSystem Requirements
linkInstallation
Panel
bgColorlightgrey
borderStylesolid
Installation
CardPageLinkLicense Agreements and Copyrights
Check detailed licensing and copyright information related to Chaos Anima.
Installation
Div
alignleft
classdashboard
Textboxcard
CardPageLinkInstallation
First Steps
Learn how to install Chaos Anima.
Licensing
Div
alignleft
classdashboard
Textboxcard
CardPageLinkChaos License Quick Start Guide
See how to activate your Chaos License once you've installed Anima.
Textboxcard
CardPageLinkLIC5:Cloud-based Floating Licensing
Cloud Floating Licensing
Cloud-based Floating Licensing allows you and your team to use a shared pool of Floating licenses entirely through the Cloud.
After Installation
Div
alignleft
classdashboard
Textboxcard
CardPageLinkLoad Anima
Load Anima
See how to launch Anima Designer and the plugin(s) in the host app.
Trial
Div
alignleft
classdashboard
Textboxcard
CardPageLinkFree Trial
Free Trial
If you are a trial user, check how to download and install Chaos Anima.
bgColorlightgrey
borderStylesolid
