Due to the technical limitations, individual asset selection is not supported in Rhino 7.
Section | ||||||
- SketchUp 2025 Support: Initial compatibility with SketchUp 2025. New SketchUp 2025 features such as photoreal materials are not yet supported and will be introduced in future updates.
- Enscape will remove unsupported host application versions from its installer three months after their official end-of-support announcement. With the Enscape June 2025 release, SketchUp 2025, 2024, and 2023 will be the only supported versions. Older SketchUp versions will be removed from the Enscape installer.
- SketchUp - Export Geometry Option for Batch Rendering and View Switching: Enscape now includes a “Geometry Update” setting in SketchUp, allowing users to control whether geometry is reloaded when switching views or batch rendering. When disabled, Enscape will not reload geometry, improving performance when navigating between views. This option is available at the bottom of the View Management panel and the Batch Rendering dialog.
