Release Notes 26.03.2025
New
  • Selective Asset Exclusion in White Mode: Users can now exclude specific Enscape assets or asset categories from White Mode, enhancing design presentations by making it easier to focus on critical project details. This enables architects, landscape designers, and urban planners to highlight specific elements while keeping the rest of the scene in White Mode. Additionally, an Invert Appearance option allows selected assets to appear in white while everything else retains its original colors and materials.
    Please note:
    • This functionality applies only to Enscape assets and Custom assets under Enscape Asset Library.
  • Allow Enscape to Start When Missing Permissions for My Documents: Users without write access to the My Documents/Enscape folder can now start Enscape on Windows, whereas previously they were blocked from using the product. A warning message will inform users about the limitations (e.g., inability to save settings or generate panoramas). The warning appears at startup unless the user selects "Don't show again."
Fixed Bugs
  • Rhino - Textures Disappear When Rotated 90° or 270°: Textures now remain visible when rotated by 90° or 270° in Rhino, ensuring proper material mapping across different rotation angles.
  • Exaggerated Ghosting on Semi-Transparent Materials: Fixed an issue when DLSS is disabled excessive ghosting effects during moving around materials with dark or transparent textures.
  • Archicad 28 - BIM Information Not Displayed: Fixed an issue where BIM information was not visible in the BIM panel when running Enscape in Archicad 28.
  • Camera Sync State Sent Too Late on Renderer Start: Fixed an issue where the camera synchronization state was delayed on initial Enscape startup in SketchUp, Revit, and Vectorworks, causing the Field of View slider in Visual Settings to remain unlocked. The camera now synchronizes correctly on startup, ensuring the correct position and locked Field of View settings from the beginning.
  • Revit - Crash When Switching Documents: Fixed an issue where Enscape occasionally crashed when switching views from a small, simple project to a larger one opened in a second Revit document.
