  • Rhino - Textures Disappear When Rotated 90° or 270°: Textures now remain visible when rotated by 90° or 270° in Rhino, ensuring proper material mapping across different rotation angles.
  • Exaggerated Ghosting on Semi-Transparent Materials: Fixed an issue when DLSS is disabled excessive ghosting effects during moving around materials with dark or transparent textures.
  • Archicad 28 - BIM Information Not Displayed: Fixed an issue where BIM information was not visible in the BIM panel when running Enscape in Archicad 28.
  • Camera Sync State Sent Too Late on Renderer Start: Fixed an issue where the camera synchronization state was delayed on initial Enscape startup in SketchUp, Revit, and Vectorworks, causing the Field of View slider in Visual Settings to remain unlocked. The camera now synchronizes correctly on startup, ensuring the correct position and locked Field of View settings from the beginning.
  • Revit - Crash When Switching Documents: Fixed an issue where Enscape occasionally crashed when switching views from a small, simple project to a larger one opened in a second Revit document.
Known Issues
  • Renderer Crash on Wrong Encoding: In some rare cases, Enscape renderer crashes when the plugin sends a specific folder to write in the case of multibyte utf8 characters.
