The currently applied variation is highlighted in blue and indicated with a check mark () in the variations list. You can search, create and delete variations as described in the table below.
Search for a specific variation using theSearchfield. It filters the variations list and shows only those variations that contain the entry from the search field. Click thebutton on the right to clear the search.
Create a new variation.
Delete the selected variation.
UI Text Box
color
light-cyan
icon
info
type
info
A yellow frame around the viewport and a yellow highlight of the variation name appear every time a change is made to the current variation to prevent you from modifying it inadvertently.
UI Text Box
color
light-cyan
icon
info
When variations are used in the Animation Timeline, a transition indicator (Image Added) appears next to them in the Variation list if the playhead is over a transition element in the Variations track.
