This page provides information on the purchasing process of actors inside Chaos Anima.
There are 2 different ways to purchase more metropoly® models to expand your library:
width40%
UI Text Box
sizemedium
typenote
*IMPORTANT UPDATE:
As of August 1, 2024, the AXYZ design webshop no longer offers any items for sale.
Also, since anima 5.6.0, the embedded shop is only be available when an anima® PRO license is detected.
width40%
So you won’t need to leave Anima and use an external browser. You can go through the complete purchase process directly from inside the Anima standalone application itself.
If you used to purchase the models from our webshop in the past, you will find the Anima alternative very comfortable too because both share almost identical interfaces and workflow.
width5%
width55%
Multimedia
nameShopping_experience_from_Anima_PRO.mp4
width70%
autostarttrue
height30%
