Proceed to click the Install button. If you need to customize your Anima installation, click the Advanced button.
width
5%
width
35%
UI Step
width
60%
Advanced Installation
Choose which Chaos Anima features to install.
Workstation – Installs Anima Designer and the plugins for the selected 3D host apps.
Render Node – Installs a version that can load and render Anima content (without modifying it) in the 3D host apps.
UI Text Box
color
light-yellow
icon
warning
The Render Node does not work with Unreal Engine.
Deploy tool – Enables a command-line deployment tool that allows you to license Anima using console scripts.
Third party libs – Installs the third party libraries required to run Anima.
width
5%
width
35%
UI Step
width
60%
Advanced Installation Host Apps
Choose which Chaos Anima plugins should be installed along with the standalone Anima Designer.
To open a second screen of options, press More.
UI Expand
title
Click More to see the rest of the available options...
UI Text Box
color
light-cyan
icon
info
When installing the Render Node only, this screen is not available.
width
5%
width
35%
UI Step
width
60%
Advanced Installation Directories
Here, you can specify the installation paths. Please check if the default folders are correct.
You can also opt to create a desktop shortcut.
width
5%
width
35%
UI Step
width
60%
Licensing
In this step, specify whether the Chaos License Server runs locally or on another machine.
If you select Remote licensing, you have to enter the IP address of your Chaos License Server in the Primary License Server field. Leave port 30304 unchanged. An Alternate License Server can be used for redundancy in case the primary one does not respond. The License Server will not install when the Remote option is selected.
When Local licensing is selected, the Chaos License Server is installed with Chaos Anima.
UI Text Box
color
light-red
icon
warning
The Alternate License Server fields do not work, yet.
width
5%
width
35%
UI Step
width
60%
At this step, you can choose where to install the Chaos License Server.
License Server directory– Allows you to enter a custom license server install directory.
Add firewall exception– Allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you must manuallyadd firewall exceptionslater. This option is available for Windows OS only.
width
5%
width
35%
UI Step
width
60%
Chaos Anima 6 is ready
Anima installation is successful.
You can choose to launch Anima upon closing the installer.
