width45%
When White Mode is enabled all materials, apart from except transparent ones, are then displayed in white color.  It is a great way to emphasize forms and volumes in a project. This style of representation is commonly used for conceptual and schematic design and gives a great overview on the interaction of spatial elements.
width5%
width50%
Image Added
White Mode
Outlines can be used to highlight individual forms, achieving a more illustrative look. The thickness of the outlines can be controlled using the outline slider. Here is a quick comparison of outlines varying from 0 to 75 percent.
width25%
width50%
Image slider
minLabel0%
maxLabel75%
Panel
borderStylenone
White mode with Outline set to 0%
Panel
borderStylenone
White Mode with Outline to set 25%
Panel
borderStylenone
White mode with Outline set to 75%
width25%
White Mode Overrides
width45%
The Selective Once the White Mode functionality is also visible in the White Modeselected, you can also use the white mode overrides, also known as the Selective White Mode functionality. It allows users to exclude Enscape asset categories , or specific Enscape assets from White Mode. This feature enables users to highlight important geometry, materials, or scenery while keeping other elements in a simplified white state, focusing attention on defined aspects of the project.
You can choose categories, individual asset groups, or from the following categories to exclude:
Fancy Bullets
typecircle
  • Vegetation
  • People
  • Vehicles
  • Furniture
UI Text Box
colorlight-cyan
iconinfo
Custom assets cannot be selected via categories in the selective white mode.
width5%
width50%
Image Added
width25%
width50%
Image slider
Panel
borderStylenone
Image Added
No assets excluded
Panel
borderStylenone
Image Added
Vegetation excluded
Panel
borderStylenone
Image Added
Vegetation and People excluded
width25%
width45%
You can choose to exclude all instances of an asset at once using the search bar.
width5%
width50%
Multimedia
nameswhite-1.mp4
width100%
height100%
width45%
Or you can manually pick assets to be excluded from the White Mode by using the Select in scene option.
width5%
width50%
Multimedia
nameswhite-2.mp4
width100%
height100%
width45%
Additionally, the Invert Appearance option allows selected assets to appear inverted, i.e. in white, while everything else retains its original colors and materials.
width5%
width50%
Multimedia
nameswhite-3.mp4
width100%
height100%
width45%
The Selective White Mode functionality applies only to Enscape assets and Custom assets under the Enscape Asset Library.
width5%
width50%
Multimedia
nameselective_wm.mp4
width560100%
autostarttrue
height389100%
Polystyrol Mode
width45%
Renders all surfaces like a real polystyrol material, whereby the sunlight is scattered through the thinned geometry.
When this mode is selected, an additional setting appears named Transmission that determines how much light is transmitted through geometry.
width5%
width50%
Polystyrol Mode and Transmission Slider
