This page provides information on the rendering styles in Enscape.
In the Visual Enscape Settings window, located under the Main Tab, a section named Style provides options to allow you to change the way that Enscape renders your projects. You will notice that the Style section contains, by default, a slider named Outlines and a drop-down menu that is named Mode. These ‘Modes’ allow a user to apply unique styles to their projects and produce a Maquette or Sciographic, Hatched Sketch, Watercolor rendered image style and lots more.
To access these options, make sure Enscape is running and then open the Visual Settings window using the associated button in the Enscape Viewport user interface, as shown highlighted to the right in the following screenshot.
Visual Settings window button
Section | |||||||||||||||
White Mode
Outlines can be used to highlight individual forms, achieving a more illustrative look. The thickness of the outlines can be controlled using the outline slider. Here is a quick comparison of outlines varying from 0 to 75 percent.
Section | |||||||||||||||||||||||||||||||||||||
White Mode Overrides
Polystyrol Mode
You can see the effect of 0% Transmission in the following screenshots with 25% and 75% outlines applied.
Align | ||||||||||
Bump Maps
Light View Mode
In the Enscape Viewport, when Light View Mode is activated, there will always be a temp range indicator located to refer to which is located at the top of the Enscape viewport window:
Light View Temperature Gauge
Sketch Mode
Watercolor Mode
It is recommended to use this artistic visual mode for still renders to achieve best results.
