width25%
width50%
alignalign
Panelbefore-after
afterLabel
Random distribution
darktrue
beforeLabelUV map
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
center
Image_comparison_slider
AddButtonsfalse
LabelBeforeRandom Distribution
LabelAfterUV Map
AttachmentImageAfter
width25%
Random Distribution
section
width5%
width45%
Image slider
startIndex1
Panel
borderStylenone
01_RandomDistribution_InstancesCount_1000
Count = 1000
Panel
borderStylenone
02_RandomDistribution_InstancesCount_2500
Count = 2500
Panel
borderStylenone
04_RandomDistribution_InstancesCount_10000
Count = 10000
width45%
Image slider
startIndex2
Panel
borderStylenone
01_PerArea_InstansesCount1000_PerAreaOff
Count = 1000; Per Square = Off
Panel
borderStylenone
03_PerArea_InstansesCount1000_PerArea1000
Count = 1000; Square Size = 1000
Panel
borderStylenone
05_PerArea_InstansesCount1000_PerArea4000
Count = 1000; Square Size = 4000
Panel
borderStylenone
07_PerArea_InstansesCount1_PerArea100
Count = 1; Square Size = 100
Panel
borderStylenone
08_PerArea_InstansesCount1_PerArea1000
Count = 1; Square Size = 1000
width5%
width5%
width45%
Example: Density
Anchor
density
density
The Square Size in this example is 500 cm. It shows how different maps create patterns of instances on the surface.
width25%
width50%
Image slider
startIndex1
Panel
borderStylenone
01_Density_IC5000_CheckerMapImage Added
Count = 5000; Checker Map
Panel
borderStylenone
Image Added
Count = 5000; Noise Map
Panel
borderStylenone
03_Density_IC5000_GradientMapImage Added
Count = 5000; Gradient Map
width45%25%
Example: Density Texture
Anchor
Dmap
Dmap
Using a Density texture generates a brand new instance distribution. The total number of instances (approximate to the Count value) is preserved and distributed on all surfaces that correspond to map values above 0 (parts of the map not being purely black). Instances are more likely to be generated in areas with higher Density Texture values than darker ones.
5%
width5%25%
width45%50%
panelborderStyle
01_Density_IC5000_CheckerMapImage Removed
imagebefore-sliderafter
startIndexafterLabel1off
dark
true
none
beforeLabelon
Panel
borderStylenone
Image Added
Image Removed
Panel
borderStylenone
03_Density_IC5000_GradientMapImage Removed
Image Added
width45%
Panel
AddButtonsfalse
LabelBeforeDensity Map Off
LabelAfterDensity Map Checker
width5%25%
UV Map
width55%
Pattern – Determines a pattern for the scattering. See the Pattern example below for more information.
Grid – Rectangular grid.
Running Grid – Rectangular grid with every other row offset by half of the grid spacing.
Hexagonal Grid – Arranges instances into hexagons.
Lock V – When enabled, the values of the V coordinate for Spacing, Jitter and Offset are locked to the U coordinate's values. See the Offset examples below for more information.
Spacing – Scales the pattern in UV space. When Spacing is set to 1, the pattern occupies the whole space. When Spacing is set to 0.5, the pattern is repeated twice. See the Spacing example below for more information.
Jitter – Determines what percentage of the instances are randomly placed. When Jitter is set to 0, all instances are placed according to the UVW mapping. When Jitter is set to 1, all instances are randomly placed. See the Jitter example below for more information.
Offset – Offsets the pattern by the given value. Keep in mind that 0 and 1 Offset gives the same result, as 1 moves the pattern by one whole repetition. See the Offset examples below for more information.
width5%
width40%
